2 oHm bass blockers
2 oHm bass blockers
Old 1st March 2012, 04:36 PM   #1
3025826 is offline 3025826
Default 2 oHm bass blockers
I'm looking for some bass blockers for my infinity refernece 4x6s. The problem I'm having is that I can only find bass blockers for 4ohm speakers. Can anyone please shed some light on what I need to do I'd like not to blow them
Old 1st March 2012, 09:24 PM   #2
Perry Babin is offline Perry Babin  United States
There were the original Bass Blockers that were a capacitor and a parallel (drain?) resistor. Knock-offs are simply capacitors. You have to know what crossover frequency you want. Then you can select the proper capacitor.
Old 1st March 2012, 11:27 PM   #3
thanks, I'm thinking around 300-400hz. Also I have some kicker 6.5s on a 300.1zx at 2ohms. Is there a really low blocker (I was thinking 75hz?) I could get for them that could handle the 150rms power I'm pushing them at?
Old 1st March 2012, 11:32 PM   #4
Use the calculator about 2/3 of the way down THIS page (the one that says 'check your math here').
It would be difficult to find a capacitor that would not withstand the voltage required to produce 150w. When you buy the capacitors, it they're electrolytic capacitors, you'll need bi-polar or non-polarized capacitors.
2 oHm bass blockersHide this!Advertise here!
4 ohm bass drvers vrs 8 ohm help!!! slr 5000 Multi-Way 6 11th August 2011 08:35 PM
PHL Bass Midrange 8 ohm vs 16 ohm - same SPL: Why ? tiefbassuebertr Multi-Way 6 28th March 2010 06:14 PM
Homemade Bass Blockers englishjg Parts 2 10th September 2008 04:05 AM
32 ohm bass amp. Tweeker Instruments and Amps 5 9th March 2006 12:43 AM
problem with bass blockers all_about the12 Car Audio 1 15th October 2004 03:08 PM
