Ground Zero Plutonium GZPA 1.3000D Schematic?
Old 1st March 2012, 10:31 AM   #1
Custom Chris is offline Custom Chris  United Kingdom
Default Ground Zero Plutonium GZPA 1.3000D Schematic?
Hello everybody! Does anybody have the schematic for the Ground Zero Plutonium GZPA 1.3000D?
I have recently acquired this amp and while it works OK and produces a clean sound (by ear), it has the following the problems:
Quiet hiss from the sub.
RCA shields to -VE reads open
-VE to chassis also reads open
Oddly, not sure if it's the characteristics of the amp, or due to the problems above, but it seems to lack bass above 40Hz.
I was going to start with checking the secondary ground resistor location. It also appears to have had a repair at some point too.
If you have this schematic I would be very grateful for it.
Old 1st March 2012, 09:18 PM   #2
Perry Babin is offline Perry Babin  United States
Do you see R727?
Old 1st March 2012, 10:13 PM   #3
Yes sir.
I had a feeling this was it. That is connected to -VE but past it, I do not know...
Old 1st March 2012, 11:34 PM   #4
One end should be connected to the secondary ground. The other end to the primary ground. In early amps, it was a 10k resistor. That was changed to a 10 ohm. The input shield is not connected to either ground.
Old 12th May 2012, 03:25 AM   #5
I pulled this back out today. I set the gains with a DMM but the amplifier still only sounds like a 1k RMS amp.
Everything looks OK on the board and it still plays well.
Does anybody have the schematic diagram for this?
Old 12th May 2012, 04:01 AM   #6
It doesn't appear to be drawing much current either...
Ground Zero Plutonium GZPA 1.3000D Schematic?Hide this!Advertise here!
GZPA Class D 4000W with IRFP264 B.I.G Class D 86 10th April 2015 08:41 AM
SPL ZX1-3000D brandes.cm Car Audio 46 25th September 2011 02:57 AM
SPL Z1X-3000D Dr Zeus Car Audio 10 1st September 2011 08:14 PM
SPL Z1X-3000D Dr Zeus Car Audio 4 18th August 2011 04:31 AM
gzpa 1.8000d margarit2001 Car Audio 1 17th March 2011 10:07 PM
