punch 500x bias voltage
Old 8th March 2012, 12:46 PM   #21
ian33 is offline ian33
I do not have one but i will find it.Is it to limit the current?
I am using a 50w light bult as a limiter.
Old 9th March 2012, 01:02 AM   #22
Perry Babin is offline Perry Babin  United States
I wouldn't use the lamp. A 12v lamp will blow relatively quickly at anything above about 15v and the amp could easily drive 20+v into the lamp/resistor.
Connect the resistor across the output and do whatever you were doing to make the amp draw current with the bias pot fully counter-clockwise. Does the resistor heat up?
Is there any DC voltage across the resistor when the amp is drawing excessive current?
Old 9th March 2012, 04:27 PM   #23
I used a 3.4 ohm 30w resistor
I connect it on the bad channel and it is not heating up.
Voltage across the resistor is .8mv
voltage across emitter resistor .3mv
Old 10th March 2012, 07:59 AM   #24
Did you do the same thing that you did when you had 4.3mv with the bias set fully counter-clockwise?
Old 10th March 2012, 11:50 AM   #25
yes,
Old 10th March 2012, 09:49 PM   #26
I don't have any more suggestions without a scope. It appeared to be oscillating but if the resistor didn't heat up, it probably wasn't oscillating.
Old 12th March 2012, 01:58 AM   #27
I will just remove the outputs in the bad ch.The owener only need on ch for a sub.
If the resistor was heating up where whould i have to check for the fault?
Thanks for the help
punch 500x bias voltageHide this!Advertise here!
Rockford Fosgate Punch 500x 4 channel seankane Car Audio 48 29th April 2011 10:46 PM
bias current on rockford punch 200.4 Ground Zero Car Audio 2 5th April 2010 05:06 PM
Punch 500aII rail voltage/Voutput brandes.cm Car Audio 11 14th January 2010 12:18 PM
Punch 500x part location? KyferEz Car Audio 10 29th September 2008 11:21 PM
bias voltage vs bias current woodturner-fran Tubes / Valves 3 24th February 2007 11:24 PM
