Amp is stuck in protection mode..
Heres what i have on the 494 Pin 1:1.23 Pin 2:3.68 Pin 3:4.74 Pin 4:6.63 and keeps climbing Pin 5:1.48 Pin 6:3.39 Pin 7:0 Pin 8:0.26 Pin 9:0 Pin 10:0 Pin 11:0.27 Pin 12:13.90 Pin 13:5.00 Pin 14:5.00 Pin 15:5.00 Pin 16:12.79 Thoose readings are with the rectifiers out of circuit.. Any ideas?? |
#2 |
Post a photo of the board. I don't have any information on that amp.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#3 |
Heres a couple pics of the board..
#4 |
There are two long jumpers for the protection circuit. Pull them one at a time to see which one is causing the amp to go into protect.
Clamp all transistor and use a current limiter. The amp may try to draw excessive current.
#5 |
I pulled the 2 jumpers circled in blue amp still doesnt power up..
Pin 16 of the 494 is still at 12.89 volts.. |
#6 |
What's driving pin 16?
If it goes back to a transistor, pull that transistor.
#7 |
I pulled Q1 (A1359) and followed the trace in the other direction as well and pulled Q6 ..
Both transistors are connected to pin 16.. I got the voltage to drop to 4.36 volts on pin 16 amp is still dead.. |
#8 |
If pin 15 is still at 5.0v, something else is also causing the IC to shut down. Post the voltages again or at least the ones that have changed.
#9 |
I put Q1 back in the amp and this is what i get now..
Pin 1:0.83 Pin 2:2.39 Pin 3:0.06 Pin 4:0 Pin 5:1.48 Pin 6:3.40 Pin 7:0 Pin 8:12.01 Pin 9:5.01 Pin 10:5.01 Pin 11:12.01 Pin 12:13.88 Pin 13:5.00 Pin 14:5.00 Pin 15:5.00 Pin 16:4.36 Last edited by mike49504; 29th February 2012 at 01:04 AM. |
#10 |
What are the numbers on the transistors?
| kicker kx1200.1 | getmoney2957 | Class D | 1 | 7th July 2012 11:24 PM |
| Kicker ZX450.2 | m4ick | Car Audio | 9 | 18th January 2012 11:26 PM |
| phoenix gold ZX450 problem | NauTech | Car Audio | 11 | 9th April 2011 06:22 AM |
| kicker zx100.2 | spaz1980 | Car Audio | 8 | 21st September 2009 05:21 PM |
| Kicker SX650.1 help | shagone | Car Audio | 12 | 19th March 2008 07:35 AM |
