MTX Thunder 81000D Problem
Old 25th February 2012, 09:10 PM   #1
zach90z is offline zach90z
Default MTX Thunder 81000D Problem
Hi I have a MTX thunder 81000D thier is a high pitched whining sound comming form the transformer but I was getting sound out of the board and when I pushed on the board it would go away.
With the whining sound the output signal was not a normal subwoofer signal.
Once I pushed on the board the signal was back to normal so I figured it was bad solder connections.
I resoldered the amp, I still have the same problem then somthing smoked but since im using a variable psu it protected the amp right away.
I started trouble shooting but without a schemtaic its hard.
I replaced 2 SMT's q264 and q263. I still have the same problem.
Im getting -70 and +70 volts from the fets. LED238 is on.
I checked chip TL494C im getting a sawtooth signal and the square wave signal to the fets is not much of a square wave it is a cross between a sine and a square.
Anyway Im kinda stuck without a schmatic at this point. So any help would be great.
Old 26th February 2012, 11:39 PM   #2
Perry Babin is offline Perry Babin  United States
If you can push on the board and make the fault come and go, you need to keep doing that until you find the component that's causing the problem.
Old 26th February 2012, 11:50 PM   #3
I did thats when a resistor or surface mount transistor smoked and now I cant get anymore sound out of it even after I replaced the bad smt's.
No other componenets look bad.
Do you happen to have a schematic for this amp?
Old 27th February 2012, 09:46 AM   #4
Are you unsure whether the component was a resistor or a transistor?
I don't have any schematic that I can distribute.
MTX Thunder 81000D ProblemHide this!Advertise here!
Mtx Thunder 280 Problem jamesl75 Car Audio 11 3rd November 2011 07:55 PM
MTX Thunder 81000D troubles mbates14 Car Audio 11 10th December 2010 06:29 AM
MTX thunder 3401 problem FUNGC Car Audio 6 14th September 2010 01:40 AM
Mtx 81000d amp Crunchy insides shaggy10000 Car Audio 7 4th June 2008 03:19 AM
MTX 81000D Noise confused256 Car Audio 2 13th July 2005 07:21 AM
Copyright ©1999-2017 diyAudio
