TOTAL DESTRUCTION OR HAPPY FET
Old 25th February 2012, 01:01 AM   #1
WSJ is offline WSJ  United States
WSJ's Avatar
Default TOTAL DESTRUCTION OR HAPPY FET
If a 12 volt amp with two 25A fuses and 4 IRF1324 FETS is connected
to a battery with the polarity reversed would the fuses protect the FETS?
If the fusses are replaced and the battery polarity is corrected will the
amp still work with a normal life span?
I have not done this, but I may have an amp that has been wired backwards.
http://www.irf.com/product-info/data...irf1324pbf.pdf
Old 25th February 2012, 01:38 AM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
You could do a quick check of the mosfets and see if they are shorted D-S.
Could be you got away with it, or you havent and you have destroyed one or more parts of the circuit.
If the mosfets test ok fire it up and see what happens.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
TOTAL DESTRUCTION OR HAPPY FETHide this!Advertise here!
Threshold FET 10/pc Phono Stage Preamp Schematics aka FET 10pc, FET-10pc, fet ten/pc krellkraver Solid State 2 17th July 2015 02:49 PM
Stopping Speaker Destruction DQ828 Digital Line Level 10 8th January 2011 10:03 PM
Gratuitous destruction PeteMcK The Lounge 4 4th July 2010 02:56 AM
Op-Amp Self Destruction Tim__x Parts 9 6th June 2004 09:50 PM
The Horn of Mass Destruction mgoedeke Multi-Way 51 3rd June 2004 01:00 PM
