working on an MTX thunder 8302. build date is 5/11/01. amp had shorted (x2)ssp45n20a. I pulled them and now the amp turns on. rail voltage is +/_ 32volts. It shows 15volts dc voltage on outputs. I have fired the amp up with a inline current limiter and measured some dc voltage at emmiter resistors for some of the remaining outputs. the lowest is .ooo5volts and the highest is .0006volts. Also all of the power supply filter and storage caps are ready to pop. Sorry for two much info in one post.
IC#494
Pin 1: 2.35
Pin 2: 2.35
Pin 3: 3.41
Pin 4: .844
Pin 5: 1.55
Pin 6: 3.44
Pin 7: .004
Pin 8: 12.76
Pin 9: .004
Pin 10: .004
Pin 11: 12.76
Pin 12: 12.81
Pin 13: 5.026
Pin 14: 5.026
Pin 15: 5.026
Pin 16:.004
IC#494
Pin 1: 2.35
Pin 2: 2.35
Pin 3: 3.41
Pin 4: .844
Pin 5: 1.55
Pin 6: 3.44
Pin 7: .004
Pin 8: 12.76
Pin 9: .004
Pin 10: .004
Pin 11: 12.76
Pin 12: 12.81
Pin 13: 5.026
Pin 14: 5.026
Pin 15: 5.026
Pin 16:.004
i called mtx and the guy that answered the phone would not release the schmatic, but verified that d92 is a 4.7volt smd zener diode. He called it model mda011. I have d92 removed and still have considerable voltage on outputs right- and left+
With a jumper from main ground to rca shielding the voltage at the outputs increases by 10volts.
Any help would be appreciated guys.
- General Interest
- Car Audio
- mtx thunder 2 channel
