This amp had 2 shorted outputs and one blown power supply. The other power supply is still in tact. The power supply that was still in tact is being regulated and the one that I am using the 3205s in has a wider pulse width indicating to me that that power supply is working harder to maintain voltage.
When I power the amp on I get -46V on the secondary CT and on the RCA shields. I'm not sure what is causing it, any help would be appreciated.
Scope - DMM - 460W Computer PSU - Tutorial Last edited by m4ick; 22nd February 2012 at 05:03 PM. |
#2 |
As a side note, the secondary CT starts at -18 volts and moments later jumps to -46.
Scope - DMM - 460W Computer PSU - Tutorial |
#3 |
Do you have both positive and negative rail voltage on the output transistors?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#4 |
Referenced from secondary CT I have +- rail voltage.
Referenced from amplifier ground I have approximately +1.8 and -96.
#5 |
Just for your information this amp uses 2 494Cs, one for each power supply. Each power supply generates separate rail voltage for each channel. + rail on one channel is not directly connected to + rail on the other.
Each of the 494s has .25vdc on pin 4 yet each one is showing different dead times.
Scope - DMM - 460W Computer PSU - Tutorial Last edited by m4ick; 22nd February 2012 at 07:21 PM. |
#6 |
Nevermind the different dead times, there's a pot for each 494 that feeds pin 1. Is there a certain pulse width I should set this to?
Other than setting the dead time, the only issue I have now is the -46v on the secondary CT. Referenced from secondary CT I have about +-48v. Both sets of rails are having the same symptoms, -46V at secondary ground.
#7 |
Is one of the rectifiers or outputs shorted to the heatsink?
#8 |
The rectifiers are in plastic cases and I don't get continuity between the center leg of any outputs and the metal plate.
Also, from a cold start the sec CT is at -18V, as soon as I turn off my power supply it jumps to the -40s and begins to discharge. Each time I start it after that without allowing it to fully discharge it goes directly to -46v.
#9 |
| Alpine MRV-1000 yet again | spooney | Car Audio | 39 | 18th May 2013 11:07 PM |
| Alpine MRV T500 | mk2singh | Car Audio | 0 | 11th December 2010 10:47 AM |
| Alpine MRV-1002 | caraudioguy2100 | Car Audio | 5 | 13th August 2010 10:41 PM |
| Alpine MRV-F401 or MRV-F400 Service Manual | M.André | Car Audio | 6 | 21st February 2010 09:37 PM |
