Flickering headlights with an earthquake phd2
Old 22nd February 2012, 02:35 AM   #1
Sinister7 is offline Sinister7  Canada
Default Flickering headlights with an earthquake phd2
Hey all. I'm going to start this off from the beginning. I have a 1999 BMW 328i that has a 120amp Valeo alternator and a brand new battery 1000 cca battery. I have 2 10" mtx 600 watt jackhammer subwoofers run in series and an earthquake phd2 amplifier. Not to sure ohm ratings and whatnot. Also the wiring was all re run 0 gauge for power with a 5 farad cap. The battery on this car is located in the trunk on these cars but there can be a second battery installed if needed. Now the problem is everytime I turn the bass up on my alpine head I get flickering headlights and interior reading lights. Soon as I turn it down with a little bass it's fine. Now doing just a draw test with the bass super loud I was getting an intermittent drop sometimes to .9 volts but for the most part it was staying at 14.1v charge. HELP!!!!
Old 22nd February 2012, 05:16 PM   #2
Perry Babin is offline Perry Babin  United States
A drop of 1 volt will make a big difference. The alternator probably doesn't have enough output current to keep the headlights from dimming. Even if it does, there's a bit of lag built into the regulator that will prevent it from keeping the voltage precisely at 14.1v all of the time.
Old 22nd February 2012, 06:59 PM   #3
Thanks. Is there another way around upgrading the alternator? Is a second battery going to make any difference?
Old 22nd February 2012, 08:05 PM   #4
A second battery probably won't make a difference. All real solutions are going to be expensive. Upgrading the alternator isn't necessarily going to solve the problem completely.
Old 23rd February 2012, 12:30 AM   #5
What's the best solution in your opinion?
Old 23rd February 2012, 11:30 AM   #6
How do you define best?
Old 23rd February 2012, 01:33 PM   #7
TheBaronGroog is offline TheBaronGroog  United Kingdom
Try whichever is cheapest 1st-check with BMW whether a larger altnerator from a higher model will fit and compare that to the cost of a 2nd battery-ultimately both is better. Try removing the cap-sometimes they can do more harm than good.
Old 24th February 2012, 03:26 PM   #8
lowered98z24 is offline lowered98z24  United States
caps only store some power but do more harm than help from what i seen.if it was me i would do the big 3 upgrade and if it still is having the same issue then its safe to add the 2nd battery.if u are unsure of how to do a big 3 it walk u through it on youtube.hope this helps
Old 26th February 2012, 01:52 PM   #9
Well I have ripped my alternator out and sent it to the rebuild shop. The brushes and slip rings are worn right out of it. So I am going to attempt a rebuild on that first. Also adding a second battery wont be very expensive at all. I got one lying around my house and there is a special place for one under the hood in the front of the car on these. I guess it was an option to have them up front from the factory in europe. All i need is the cables and battery tray.
Old 26th February 2012, 11:12 PM   #10
Extra batteries won't generally help unless the voltage is dropping to below 12v. Even then, they won't help much. If the alternator charges at 13.8 and the voltage drops to 12v, the lights will dim significantly.
Flickering headlights with an earthquake phd2Hide this!Advertise here!
Earthquake PHD2 amp fongman Car Audio 8 30th November 2016 12:59 PM
Earthquake PHD2 Hectorscaraudio Car Audio 1 14th November 2011 10:10 PM
Earthquake PHD2 seems to lower output??? ppia600 Car Audio 94 14th November 2011 07:46 PM
Earthquake D200hc/phd2 modification? spooney Car Audio 32 19th March 2010 03:51 PM
PPI A600 or Earthquake PHD2? Which for two 12" in your opinion?? ppia600 Car Audio 5 7th September 2008 03:45 PM
