US Amps VLX3DE
US Amps VLX3DE
Old 21st February 2012, 05:36 AM   #1
timwebb is offline timwebb  United States
Default US Amps VLX3DE
i have this amp in and its dead. i cant get it to do anything. anyone worked one these?
Old 21st February 2012, 07:33 AM   #2
Perry Babin is offline Perry Babin  United States
If no one can help, post a photo of the board.
Old 21st February 2012, 06:51 PM   #3
Old 22nd February 2012, 11:57 AM   #4
The amp is going into protection now but no voltages on both of the 494 ic.
Old 22nd February 2012, 06:22 PM   #5
Follow the circuit back from pin 12 of the 494 to see what's supposed to be driving 12v to it.
Old 23rd February 2012, 09:29 AM   #6
ive traced it back to this diode but cant find the data sheet on it
Old 23rd February 2012, 11:25 AM   #7
Ok. I found it...trying to work on something half sleep. Anyway the diode is us1m-e3. It read 1.5 with diode check. Its connected to pin 12.
Old 23rd February 2012, 12:47 PM   #8
I think that diode is likely across the relay coil (confirm).
If so, you need to follow the trace back farther, possibly all of the way back to the remote turn-on terminal.
Old 23rd February 2012, 01:23 PM   #9
I think pin 8 and 12 are connected.the trace for pin 12 goes under the 494. Those the only two pins I read 0 ohms. I'm think the trace leads to the other driver card.
Old 23rd February 2012, 09:03 PM   #10
You should read 0 ohms between 8 and 11.
You'll have to follow it back farther.
The trace may go to the other driver board but it may also go somewhere else. The other driver card isn't likely the source of power.
US Amps VLX3DEHide this!Advertise here!
Burr Brown op amps,in amps,power op amps for sale magneticnorth Vendor's Bazaar 1 23rd September 2010 11:50 PM
which NAD older generation amps & integrated amps are bipolar or mosfet? audionaut99 Solid State 3 21st May 2010 11:09 AM
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 06:04 PM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 11:27 PM
Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? percy Chip Amps 31 13th January 2006 02:33 AM
Copyright ©1999-2017 diyAudio
