#21 |
Are there any other protection circuit designs used?
#22 |
In most of the class D amps that use the low resistance shunts, op-amps are used because the voltage drop through the resistors is too low to forward bias a transistor. In class B and class AB amps, the voltage across the emitter/source resistors is enough to forward bias a transistor so a transistor can be used.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#23 |
well, these two amps that wouldn't run at 1ohm strapped (rising to 2ohm total) are now in a different setup, running at 0.5ohm each no problem so far...
Failed setup was two Elevation Audio SQX 12's, dual 4ohm coils, all four coils in parallel (0.975ohm DC resistance, rising to 2ohm) The setup that is now working, is four Pioneer 305c subs, single 4ohm, all coils in parallel (0.75ohm DC resistance, rising to 1.9ohm) All in all, I don't get it. |
| Atomic AT-5000.1D | mike49504 | Car Audio | 19 | 24th August 2011 01:58 AM |
| Need sundown saz-3000d audio driver board info/pic | 807tubenut | Car Audio | 17 | 11th March 2011 05:47 PM |
| Sundown SAZ 3000 D | mike49504 | Car Audio | 36 | 8th November 2010 08:56 PM |
| Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D | jaimegmr | Car Audio | 0 | 5th May 2009 06:39 PM |
| hill dx1500 schematic | monkeypuzzle | Solid State | 6 | 28th June 2007 03:27 PM |
