MTX Thunder 2300x 45 volts coming from negative speaker terminal
Old 18th February 2012, 01:52 AM   #1
sportdiver is offline sportdiver  United States
Default MTX Thunder 2300x 45 volts coming from negative speaker terminal
I have had a MTX thunder 2300x for awhile, and I just pulled it out of storage and tested it to make sure everything was good before using it. The left channel works just fine, but the negative terminal for the right speaker is putting out 45v dc. I can also hook a speaker to the positive of the right terminal and the positive of the left terminal and it works. I figured I would ask here and see if anyone has had this problem before opening it up. Is there any companies I can send it to for repair? Will MTX repair it? Or is it cheaper to get a new one? How hard is is to do myself? I used to be an electrician, so I'm familiar with electrical, just not a whole lot of circuit boards. Thanks for any input.
Old 18th February 2012, 02:44 AM   #2
The black capacitor in the middle of the one picture definitely did burst.
Old 18th February 2012, 02:52 AM   #3
Also two resistors that were not connected.
Old 18th February 2012, 08:57 AM   #4
Perry Babin is offline Perry Babin  United States
Did you check the output transistors to see if any were shorted?
If you're new to amp repair, read the basic repair page (link in sig line below).
MTX Thunder 2300x 45 volts coming from negative speaker terminalHide this!Advertise here!
MTX RT251D Getting 40V across speaker terminal turbosundance Class D 4 13th August 2014 09:08 PM
Mtx Thunder 2300X mike49504 Car Audio 2 2nd February 2012 05:28 PM
MTX 2300x Cr@sh Car Audio 10 3rd August 2011 01:36 AM
orion hcca250r, kicker zr 1000, mmats d800.2, mtx 6500d, mtx 942, rockford punch 45, ernie cosillos Swap Meet 3 12th February 2011 11:14 AM
FS: Older school MTX 2300x and 2150x odinsragess Swap Meet 0 9th September 2009 11:16 PM
