Power Acoustik A2400db
Old 16th February 2012, 06:22 PM   #1
rrae is offline rrae  Norway
Default Power Acoustik A2400db
Well, driver board have seen better days. Fan had fail'd, q124 and 125 have been overheated. Someone before had repaired it. Whats the value of R190 and C191? C191 have replaced with 47R resistor... What model is IC1? The numbers is brushed off, i would like to replace it.
Old 16th February 2012, 10:57 PM   #2
Perry Babin is offline Perry Babin  United States
The IC is an NJM4580. I've never seen a defective one.
C191 is a 220 ohm resistor. R190 is a 1.2k ohm resistor.
If the board got hot, it may have become conductive. If you shine a bright light from the back of the board, there should not be any dark areas that you cannot see on the surface of the board. If there are dark areas, the board has likely become conductive.
Power Acoustik A2400dbHide this!Advertise here!
Power Acoustik A2400db timwebb Car Audio 7 18th April 2011 07:13 AM
Power Acoustik TS980 sparks, blows fuses even without power on. BoeroBoy Car Audio 7 30th September 2010 02:17 PM
Power acoustik schematic brandes.cm Car Audio 11 21st January 2010 11:15 AM
Need output chokes for power acoustick a2400db ppia600 Car Audio 11 4th September 2009 01:43 AM
Power Acoustik A2400db spooney Car Audio 21 19th March 2008 12:05 AM
