hi...
I need to build a Subwoofer box for car use. I already have a 10 in sub in hand. It does well in a vented box of 60L 35Hz tuned for in home use(now using for my computer audio system. Now i want to build another subwoofer box based on this subwoofer driver for my car use So any advice of what type of box should i use (i am currently driving a car with a small trunk size .... toyota corolla AE111) ...Thanks alot .... |
#2 |
Do you have specs for the sub? If you do download winISD and model it. Figure the car will have some cabin gain so you can get away with less low bass than in a house. WinISD is free and pretty easy to use, there are posts all over the net on how to use it. Mostly it will get mad if you input certain values it calculates such as qts. Only put in qts if you do not have other q values. Then you can make the box size anything you want and see the response curve, just click and drag on the box to change it or enter a size.
#3 |
What kind of sub? What amp will you will be using? What type of music you listen to is also important.
| I have 2 Boston G5 Car Audio Subwoofers (sound quality type) For home use? | ta_nhra02 | Subwoofers | 5 | 20th January 2010 05:20 AM |
| DIY home theater subwoofer with car audio subs! | Rockworthy | Car Audio | 5 | 3rd October 2009 07:12 PM |
| Car audio versus HiFi drivers in ELF or Linkwitz subwoofer | halfgaar | Subwoofers | 28 | 15th August 2008 10:17 AM |
| Help on Dual Chamber Reflex box & car audio response Q's please (LONG) | beady | Car Audio | 7 | 6th August 2004 11:57 AM |
| Car Ported Subwoofer: Can the port be Outside the box? | Noob-in-a-Camry | Subwoofers | 11 | 23rd May 2002 01:59 PM |
