MTX Thunder 81001
MTX Thunder 81001
Old 17th February 2012, 04:29 PM   #21
Perry Babin is offline Perry Babin  United States
What's the DC voltage on the 3 legs of FET192?
Old 17th February 2012, 04:52 PM   #22
mike49504 is offline mike49504  United States
Leg 1:-79.9
Leg 2:1.28
Leg 3:-82.0
Old 17th February 2012, 04:58 PM   #23
You probably have open resistors or defective transistors in the circuit driving this transistor.
Old 17th February 2012, 05:10 PM   #24
Im going to check the circuit and go get some resistors / transistors if needed...
will post results later..
Old 19th February 2012, 08:03 AM   #25
Do you have another pic of the area around FET401 Its right next to
Fet192..
Also a pic of the other side of the board around the rectifiers ?
Someone has worked on this before and wanna make sure they are the correct parts that are in it..
Fet 192 and Fet401 are 540's correct?
Old 19th February 2012, 08:59 AM   #26
I think FET401 is an N-channel FET but I'm not 100% sure. FET 192 is a 540.
Old 19th February 2012, 09:02 AM   #27
In the amp i have Fet191 has a diode solerd to leg 3 is that suppose to be there or did someone add it ?
Wondering if i should ake it out or not ?
Old 19th February 2012, 09:12 AM   #28
Leave the diode. I think it's to help protect the op-amps when the regulator fails.
Old 19th February 2012, 09:17 AM   #29
Ok will do..
Hopefully all the right parts are in this amp someone has worked on this before and has been all over the board..
The amp i have here Fet192 Fet401 Fet191 all have IRF540's in there locations..
Also i rebuilt the area around Fet192 Replaced all resistors transistors and the regulator..
As soon as i powerd it on the fans spun for 1 sec then Q109,Q111,D105,Q108 all failed again..
Old 26th February 2012, 03:49 AM   #30
Ok finally got the parts in for this amp..
I now have + - 15 volts on the op-amps..
Now i have 81 volts of DC measured directly across the speaker terminals..
All outputs test fine..
Any ideas where to go next?
MTX Thunder 81001Hide this!Advertise here!
MTX Thunder 81001 mike49504 Car Audio 10 28th November 2012 04:46 PM
Mtx Thunder 2300X mike49504 Car Audio 2 2nd February 2012 06:28 PM
MTX Thunder 81001 fets fragmental Car Audio 16 8th October 2010 05:29 AM
MTX thunder 81001 board mvp171-c identify 4 burned resistors mobilepcrepair79 Car Audio 4 21st September 2010 03:57 AM
MTX Thunder 81001 megael9 Car Audio 13 30th May 2010 04:23 AM
Copyright ©1999-2017 diyAudio
