Board # PC-5445-C
Pass a schematic along if you have it. brandes.cm@gmail.com Sometimes it will produce audio other times it won't. I replaced the gain pot and cleaned the cross-over pot. The signal would get all flakey when adjusting either one. Maybe the cross-over pot is still messed up. I didn't have a small enough bolt to replace the rivet that held it together. So I used some wire and twisted it after feeding it through the hole. |
#2 |
Post a pic of the pots you need. I have several hundred in stock I might have what you need and can get it to you faster than your normal parts order.
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#3 |
Mouser has the parts I need, it's the standard 4 gang carbon Bourns pot (20K). I have a mess of parts to order anyway.
That is my issue with the amp as well, push on the pot and signal returns. |
| outputs for RF | ian33 | Car Audio | 3 | 2nd February 2012 03:06 AM |
| Laser Pickup´s M52103FP RF-Amp instead of older CX20109 RF-Amp | Salar | Digital Source | 2 | 25th July 2010 05:44 PM |
| for the RF 's | tomtt | Everything Else | 11 | 9th May 2010 02:03 AM |
| RF filtering | kzsolt | Solid State | 4 | 6th April 2010 07:24 PM |
| T1000bd fried? | gtr0manc3r | Car Audio | 1 | 7th March 2007 03:57 AM |
| Page generated in 0.06983 seconds (71.50% PHP - 28.50% MySQL) with 10 queries |
