Im working on an amp and notcied the output filter inductor was broken off the board..
1 lead that solders to the board is still fine.. The other lead snapped in half so now its about 1" to short.. Wondering if anyone knows of a good was to extend the lead about 1" and have it be reliable ? |
#2 |
You can solder a wire to it to extend it. What's important is securing the body of the inductor so that the leads are no longer stressed when the amp is subjected to vibration.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
I dont think the output filter inductor is any good.. I solderd a wire to it resolder it to the board..
Amp powers up with no output and the inductor gets hot so i tryed twisting it somewhat when i did that the amp drew excessive current i twisted it somemore so the amp wouldnt draw current.. Inductor still gets hot would this be caused by a bad inductor or another componet? |
#4 |
Inductors get hot when in good working condition. If you can change the current draw by twisting it, it's likely intermittently shorted but it's also possible that you're flexing the board and causing another intermittent problem to show up (although I'd bet on the shorted inductor).
The inductor likely has multiple shorted windings. Adjacent windings shorting don't cause as much current draw as windings that are more turns away from one another.
| TDA8924 filter inductor | ghabrius | Class D | 8 | 24th April 2011 09:04 PM |
| heating in inductor ( LC Filter ) | yanuarbob5150 | Class D | 3 | 23rd September 2008 10:19 AM |
| smps output filter inductor design | zilog | Power Supplies | 7 | 30th August 2008 11:47 PM |
| SMPS Output filter inductor calculation. | corrieb | Car Audio | 7 | 28th October 2005 03:47 PM |
| ~30mH inductor for use in pi filter | Zodiac | Parts | 6 | 29th September 2003 10:38 AM |
| Page generated in 0.07051 seconds (70.26% PHP - 29.74% MySQL) with 10 queries |
