MTX thunder 4200x  no audio
Old 9th February 2012, 09:42 PM   #1
ian33 is offline ian33
Default MTX thunder 4200x no audio
hi all
This amp came in with broken rca input.I replace the rca input jacks but i do not get no audio.This amp has - + /14.3v on the rail is that normal?
All opamps have - +/9.1v
I am getting audio on most of the opamps using a small amplifer.
Any idea what to check next?
Old 9th February 2012, 11:57 PM   #2
Perry Babin is offline Perry Babin  United States
Those voltages seem low. What do you read across the B+ and ground when you only have 15v of rail?
Old 10th February 2012, 12:07 AM   #3
13.6v
Old 10th February 2012, 01:02 AM   #4
Post the DC voltage on all of the pins of the 494.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Old 10th February 2012, 01:47 AM   #5
494
Pin 1: 1.56
Pin 2: 3.06\3.08
Pin 3: .05
Pin 4: 3.31
Pin 5: 1.45
Pin 6: 3.25
Pin 7: .00
Pin 8: 13.06
Pin 9: .01
Pin 10: .01
Pin 11: 13.14
Pin 12: 13.11/13.14
Pin 13: 4.88
Pin 14: 4.88
Pin 15: 4.87
Pin 16: .04
Old 10th February 2012, 01:56 AM   #6
Follow the circuit back from pin 4. If it goes to a PNP transistor's collector, remove the transistor and power up the amp (all transistors clamped tightly to the heatsink and 10-15 amp fuse in the B+ line).
Does that allow it to power up and produce clean audio?
Old 10th February 2012, 01:20 PM   #7
It is connected to MPSA56.I removed it amp plays good audio and has - +/22.32 rail voltage now.MPSA tested good off the board.where should i go from there?
Old 11th February 2012, 06:57 AM   #8
What is the base of the MPSA56 connected to? If it connects to one of the pins of the LM339, post the voltages on that IC.
Old 11th February 2012, 11:24 AM   #9
The base is connected to pin 4 on the LM339 through a 10k resistor.It is also connected to the themistor through that same resistor.one end of the resistor is directly connected to the base of the same MPSA56 and the next end is directly connected to the emitter.
LM339
Pin 1: 4.69
Pin 2: 4.69
Pin 3: 12.39
Pin 4: 4.88
Pin 5: 7.46
Pin 6: 3.53
Pin 7: 4.88
Pin 8: .83
Pin 9: 3.36
Pin 10: 4.64
Pin 11: 3.36
Pin 12: .5mv
Pin 13: 1.1mv
Pin 14: 4.68
mpsa56 pads
c:.66
B: 4.74
E: 4.86
Old 12th February 2012, 11:43 AM   #10
Are you sure that the base isn't connected to another pin (1, 2 and 14?) of the 339 via a lower value resistor?
Are you sure that the A56 isn't leaky?
MTX thunder 4200x  no audioHide this!Advertise here!
MTX Thunder 4250 D mike49504 Car Audio 10 5th January 2012 03:00 AM
FS: Mtx audio jackhummer jh600 and thunder 600xd ivkata Swap Meet 1 9th December 2011 10:31 PM
MTX Thunder 2160 Rabbi Car Audio 5 14th March 2011 09:45 PM
MTX Thunder 1501D spooney Car Audio 49 16th July 2010 04:55 AM
Mtx Thunder 2300 vypr Car Audio 35 21st September 2006 07:35 PM
Copyright ©1999-2017 diyAudio
