JL Audio 1000/1 no mono outout
Old 18th March 2012, 12:27 AM   #11
DREW028 is offline DREW028  United States
Send a message via AIM to DREW028
I have corrosion in a few feed throughs on the pre amp board. They are not as bad as the ones in the photo but you cannot see through. Is there something I could spray on and maybe blow them out with air?
Old 19th March 2012, 01:13 AM   #12
Triden312 is offline Triden312  United States
If there is corrosion, most likely it has damaged the foil in the Via's. Your better off drilling them out, scraping the runs on each side to remove the coating and soldering a jumper wire through the Via, where ever there is corrosion.
Old 19th March 2012, 06:28 AM   #13
Perry Babin is offline Perry Babin  United States
Yep. What he said. The green substance is what's left of the copper that connects the traces on each side of the board.
JL Audio 1000/1 no mono outoutHide this!Advertise here!
jl audio 1000/1 repair klangston76 Chip Amps 2 12th September 2012 03:59 PM
JL AUDIO 1000/1 mike49504 Car Audio 55 11th September 2012 05:28 PM
JL Audio 1000/1 Dr Zeus Car Audio 33 8th February 2012 02:18 AM
JL AUDIO 1000/1 ALPINE AJ Car Audio 3 22nd August 2011 04:45 PM
Jl audio 1000/1 mike49504 Car Audio 1 22nd May 2010 08:21 PM
