i got this amp to repair and two driver board have corrosion as well as a few caps on top. so i powered it on to get a quick look to see what was going on.the amp looks to be fixed a few times. the amp doesn't power up all the way it doesnt even put out a signal for the power supply transistors. im sure the sg3525ap is shutting down.
#2 |
the shut down pin voltage is about 20v. i cant find whats causing it.
#3 |
The datasheets states that the maximum input to the logic inputs is 5.5v. 20v may have destroyed the logic section of the IC. You need to follow the circuit back from that pin to see what's driving it.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
ok it getting 5v. there are two smd diodes labeled v. one is good the other gives no reading at all. i did not see it in a smd code book i have.
#5 |
You're going to have to provide WAY more information if you want help finding a replacement.
#6 |
in the picture its d7.still dirty from who repaired last. im cleaning it up.
#7 |
My closest guess is a 1SS355. That's what alpine lists it as for the diode in the attached image.
| Page generated in 0.07169 seconds (75.35% PHP - 24.65% MySQL) with 10 queries |
