Go Back   Home > Forums > General Interest > Car Audio
Old 8th February 2012, 06:51 PM   #1
azvrt is offline azvrt  Netherlands
Default PPI AX400 Art Series advice
Just purchased my first PPI, an old AX400 from the Art Series.
I hooked it up to my power supply, it idles around 1.2 ampere.
Checked the DC offset, which was very good on one of the 4 channels (less than 5 mvDC).
On another channel it was not good nor bad, around 20 mvDC.
On another channel it was dramatic, around 200 mvdc.
On another channel it was worse than dramatic, around 3.3 volts !
Checked Perry's tutorial and found some very interesting information.
I had already noticed 4 pots in the outputs, presumably for the bias, and 4 pots in the input section, according to Perry's tutorial for DC offset. Very handy ! Just like my Adcom.
Anyway, I should be able to get the 5 and 20 mvdc right, I might or might not be able to get the 200 mvdc right, but the 3.3 volt channel must be in bad shape, as pointed out in the tutorial.
Anyone have the schematics for this particular amp ? Any advice ?
I'll return to my father's place tomorrow and adjust the DC offset where possible.
I must say that it was very variable. For instance, on the 200 mvdc channel, it actually was 330 at first, later it was 180. Same for the other channels, while the amplifier was warming up the offset would change quite a bit. Is this normal ? Seems like a lot of difference, 180 / 330 mvdc.
Here are some pics of the board LOTS of thermal compound, got it all over my clothes
Old 8th February 2012, 07:26 PM   #2
marko is offline marko  United Kingdom
yes, PPI liked to slap loads of thermal paste on back in the day!!
Old 8th February 2012, 07:30 PM   #3
Obviously, yes
Old 9th February 2012, 09:06 AM   #4
Also, does anyone know at which locations to measure the bias on this amplifier ?
And how much mvdc it is supposed to be set to ?
Old 9th February 2012, 09:45 AM   #5
pergo is offline pergo  Italy
the DC offset changes with temperature. It may drift.
You have to keep it under +-50mV, better near 0mV obviously.
Old 9th February 2012, 04:55 PM   #6
The voltage across the emitter resistors is the way to determine the idle current on most amps. If you don't have the bias specifications, on most amps, 0.001v across the emitter resistors is close enough.
Remember, the transistors MUST be tightly clamped to the heatsink when you do this. If they are not, the bias won't be the same after you reassemble it AND there is a great risk of blowing the outputs. You'll need to make clamps to hold them down.
Old 9th February 2012, 05:03 PM   #7
Thanks Perry.
Any idea where to start looking for the cause of the 3 volt DC offset ?
Old 9th February 2012, 05:14 PM   #8
DREW028 is offline DREW028  United States
Send a message via AIM to DREW028
Which tutorial for DC offset are you referring to?
Old 9th February 2012, 05:19 PM   #9
Perry's repair tutorial which can be purchased on bcae1.com
Old 9th February 2012, 05:23 PM   #10
What is the DC voltage on pins 3 and 4 of the driver board?
Do you have the same supply voltage on pins 1 and 15 of the driver board in both channels?
Are the 100 ohm resistors (under the driver transistors on the driver board) within tolerance?
PPI A100 (Art Series) needs repair/advice nattyTread Car Audio 8 23rd February 2010 11:02 PM
PPI ART Series a404 "v" PPI Powerclass pc450 swap chemhaz Car Audio 2 21st November 2008 02:23 PM
what's comparable to the ppi art amps? havieri23 Car Audio 2 22nd April 2008 05:07 PM
Page generated in 0.10060 seconds (81.86% PHP - 18.14% MySQL) with 11 queries
