diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   ALPINE MRD-F752 1 BAD TRIPATH TA0102A REPLACEMENT QUESTION (http://www.diyaudio.com/forums/car-audio/206213-alpine-mrd-f752-1-bad-tripath-ta0102a-replacement-question.html)
ivkata 7th February 2012 10:27 PM
Ok I've got this amp years ago and 1 of the tripath modules is bad and will get the amp in protection mode.If i do remove it from the board amp will power on and work in the front/rear channels with the other 2 tripath's modules left.
I can move one of them to the subwoofer channel and will get audio out as well so I'm thinking other than this bad module i don't have any other issues with the amp.
Model of the module is ta0102a and I'm unable to find one to replace as i want the amp working fully to power on whole car audio system.im finding ta0103a and ta0104a all over are there any options I'm missing
Perry Babin 7th February 2012 10:43 PM
The module may be repairable. Inside, there is a circuit board with SMD components. You may get lucky and one of the drivers or resistors driving the outputs is defective or has a bad solder connection.
ivkata 7th February 2012 11:03 PM
ok just removed the cover it all looks good . will test all transistors and see where we go
so 3 transistors have short between left and middle leg so i believe them being defective and causing the problem .how do u figure out whats the part number on those 1d9 and 2l8 as what it says on them
Perry Babin 8th February 2012 12:21 AM
The SMD Code Book
Try to match the code. The 1st two characters may be the only significant ones. If you get possible matches, you'll have to match the case. You'll need dial calipers to measure the case to match them.
If there is still a question as to what they are, you'll need to find another one that's identical and check it to determine if it's NPN or PNP.
Resources saved on this page: MySQL 18.75%
