Go Back   Home > Forums > General Interest > Car Audio
Old 7th February 2012, 03:20 AM   #1
Default Rockford Fosgate Power 351M
When i removed the bottom cover i noticed D1 was unsolderd from the board..
I soldered it back down ..
All outputs, source resistors, and rca shields test fine..
When i power it up it idles perfectly..
I get 0.00 volts across the speaker output terminals
When i connect a speaker to it the amp starts drawing excessive current and the speaker flutters ..
Any ideas where to begin looking?
Old 7th February 2012, 03:36 AM   #2
seankane's Avatar
Have you checked the RCA ground pins to the board to see if they are broken?
D1 will probably need replacing it is the IN4003 correct?
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 7th February 2012, 03:40 AM   #3
D1 was ok..
I found the problem D7 was defective...
Old 7th February 2012, 03:44 AM   #4
seankane's Avatar
I have had D7 fail before on many amps and the speaker flutters and the amp produced alot of feedback. I usually relace D1 and D7 just for good measure.
Alot of times D7 tends to fail after the ground pins on the RCA plugs has been broken. Maybe just a coincidence not sure.
Rockford Fosgate Power 1100a2 seankane Car Audio 4 30th May 2011 01:38 PM
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Rockford Fosgate Power 360a2 seankane Car Audio 219 26th April 2011 07:37 AM
Rockford Fosgate Power 1000a2 seankane Car Audio 31 6th April 2011 04:23 AM
Page generated in 0.06112 seconds (71.45% PHP - 28.55% MySQL) with 10 queries
