Go Back   Home > Forums > General Interest > Car Audio
Old 6th February 2012, 07:08 PM   #1
Default Sound stream usa 364
I have own this amp for several years. Was working fine till one day it smoked. I pulled amp apart and both fuses were blown and found a burnt resistor. I checked all outputs, fets, and rectifiers, all check good with the resistor removed from the board. I installed new resistor and checked the 2 rectifiers again and the fen16ct's read bad in the board. Removed from board and both check good just like they do in the board with out the resistor in it. I also noticed that when negative lead of dvc is on any - speaker terminal i have continuity on all rca grounds except channel 3 and 4 and left channel of 1 and 2. I am a begginer and need help as I dont want to see this amp go. I have read many pages on parry babins site but still can not figure this out.
Old 7th February 2012, 02:26 AM   #2
"except channel 3 and 4 and left channel of 1 and 2"
Can you clarify this, please? I am little confused.
Old 7th February 2012, 04:11 PM   #3
Default Soundstream usa 364
If you put meter on diode checker with the audible signal and touch the two leads together it buzzes at you. So if you put black lead from meter on the speaker negative terminal and touch the outside of the rca which is its ground the meter will buzz showing continuity on all the rca jack grounds except channels 1,3,4 . Even on the low pass and high pass out it shows continuity
sound stream xta720.4 *protect ian33 Car Audio 4 29th August 2010 06:52 PM
Sound Stream SA245 repair help grjr Car Audio 4 29th December 2008 07:25 AM
Sound Stream Mc-245, No Power!..help! JT_mechanic Solid State 0 27th May 2008 10:37 PM
sound stream any good? 1needforspeed Car Audio 6 20th March 2005 02:09 PM
information needed...Antique Sound USA PA-3 preamp Original Burnedfingers Tubes / Valves 16 9th June 2003 12:41 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
