Go Back   Home > Forums > General Interest > Car Audio
Old 5th February 2012, 02:20 AM   #1
DJM420 is offline DJM420  United States
Question Buzzing Amp/subwoofer issue
So i got a JBL cs300.1 Amp and was exited to hookup my sub. Well i connected everything up correctly (so i think) and when i turned the head unit on, the sub was making a loud buzz / quiet, fast popping and the power lights on it were flashing fast. I disconnected the sub, and the amp itself was making the buzzing noise with flashing lights. Disconnected RCA and same thing. The ground is fine, RCA cables/remote on opposite of power cable...I'm stumped! Unless the amp needs repair. i have some pics too. Any help would be greatly appreciated.
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
^^^^IS THIS MY PROBLEM???
Old 5th February 2012, 05:46 AM   #2
ivkata is offline ivkata  United States
most likely amp issue.If u just purchased it ,someone might sold u s... people do that.try powering the amp thru small 10-15 amp fuse and post what does it do
Old 5th February 2012, 07:07 AM   #3
i'm trying to see where that liquid came from. if the previous owner had it in storage, it verry well could have worked last time he used it. depending on what that liquid was, it could be corrosive over time, or conductive, or from a cap that is no longer good. it is probably going to need to be cleaned off before testing the amp
Old 5th February 2012, 05:58 PM   #4
do you mean use smaller fuses? I have two 25 amp fuses in it. It was getting power just not sending sound to the sub-woofer, just the buzzing. It wants to run, it turns on just starts buzzing. The missing ''R48'' in the last photo couldn't be the problem??
Thanks for the replies
Old 5th February 2012, 06:05 PM   #5
Power it up through a single 10-15 amp fuse. If the fuse blows, you need to check the output transistors. One may be shorted.
If you haven't done so and want to repair the amp yourself, read the entire Basic Amp Repair page (link in sig line below), even the parts that you don't think are important.
The resistor was likely not installed. If it would have heated enough to desolder itself, the board would be darkened under it. If it would have been ripped out, the legs would likely have remained in the board.
Old 5th February 2012, 06:08 PM   #6
No the empty resistor spot might be like this from the factory.try to clean the spill on the board .install 1 10-15 amp fuse instead of the 25 amp ones.like this u limit the current thru the amp and hopefully preventing further damage.Did u just purchased this amp ??
Old 5th February 2012, 06:35 PM   #7
Thank you for the replies. thanks Babin for the links. I got this off of Craigslist months ago...don't think I'll do that again. I'll try an hook it up again with a 15 amp fuse and see what it does. I'll post up results later or tomorrow.
Old 5th February 2012, 06:45 PM   #8
Craigslist is notorious for sellers scamming people from their hard earn cash. at least 50 times shady people have tried to sell me blown amp as god for allot less that what the amp is worth. always test before u hand over cash
Old 5th February 2012, 08:02 PM   #9
So i hooked it up again today but, not with a 15 amp fuse, I used a 25 amp fuse. I turned on my head unit, went to the amp, it had power, but was making the buzzing noise with the lights blinking erratically, And then the fuse blew after about 20 sec. and it turned off. I did not have the sub hooked up to the amp and volume was low.
Old 5th February 2012, 08:07 PM   #10
some one sold u a lemon.Read Perry's basic amp repair pages once done if u have a digital mulitimeter test all power/output transistors for bad ones u most likely have some.If its a high pitch "hissing noise " its most likely blown capacitor witch will explain the fluid leaked on the board
Subwoofer box rattle issue qa9b Subwoofers 17 1st January 2012 07:41 PM
If space is not an issue, SIX subwoofer options noviygera Subwoofers 11 23rd April 2011 02:28 AM
Need help with Ampeg J-20 crackling buzzing hissing noise issue/blocking distortion? mfcpj Tubes / Valves 0 12th April 2010 09:34 AM
Subwoofer & Amplifier Issue villeneuve Subwoofers 3 1st August 2009 01:09 PM
Page generated in 0.10426 seconds (81.66% PHP - 18.34% MySQL) with 10 queries
