Go Back   Home > Forums > General Interest > Car Audio
Old 2nd February 2012, 04:34 PM   #1
Default SoundStream 700sx w/bad transistors
Am currently working on a SS 700sx. When I first got it, it had Q55 & Q59 blown up and three resistors that were toasted (R135, R190, R171). So I checked the output transistors (TIP102 & TIP107) and seemed like there were also bad. I also had to replace two transistors Q47 & Q49 because I broke them off of the board.
So I replace all those parts with new ones. The Q47 & Q49 were also replace with new ones (dont know if I should of replaced all of them Q47-Q52, or if it matters).
I placed board back in chassis and tightly screwed all the transistor clamps. I powered it up and it played but very low and distorted, then after 10 seconds I could smell smoke and cut it off right away (I believe I used a 15amp fuse when I powered it up). Opened it up and again Q55 & Q59 both where blown completely and when I checked the TIP102's & 107's and 12 of them where shorted (Q25,26,27,28,41,43,29,30,31,32,42,44) so I removed all 12 of them and now have no clue what to do.
Am afraid that if I replace those 12 TIP transistors the same will happen (and their not cheap) not to mention the Q55-MPS8599 is no longer in mousers warehouse and I only have one left.
What should I check?
Old 2nd February 2012, 04:59 PM   #2
Q59 is the amps protection device for the right channel and is tied to the emitter resistor and the output to detect DC voltage drop which must be present in huge amounts by the failures your telling us about.
Q55 is the transistor just after that is used to combine both Q59 and Q56's output back to U7A a TLO-72 op-amps that seems to control high or low current operations leds and interface to the PWM controller.
It is likely that the FEB driver board has failed, it can be repaired and possibly replaced new thru Jaime at jandrelectronix@aol.com. This along with all the outputs replacement should bring that channel back to life. A simple DC voltage check across the speaker terminals will tell weather or not the transistors Q55 and Q59 will burn up again. But this would be doubtful with the entire channel repaired with new outputs and a new or repaired FEB driver board.
Oh I would also check each individual emitter resistor as they like to burn open on failures like this and they also must be in spec to get the channel repaired. And once the channel is repaired a simple voltage drop measurement across each emitter resistor will tell you if you have any mismatched output transistors that need to be removed and replaced with better matching devices. < this is how SS repaired these amps so I would follow this last step carefully IMHO >... Hope this helps some..
PS: You said the amp turns on and play at very low levels on the one channel that is still intact. This makes me think it also has issues perhaps some DC voltage on its speaker terminals also. I would also check all of those outputs in that channel and all of their respective emitter resistors. I have seen people run these amps into submission on subs before and both channels were badly damaged. Hope that is not the case for you here but with the info you listed it sounds like both channels may be damaged not just one...
Old 2nd February 2012, 05:27 PM   #3
The TIP102/7 are less than $0.40 each at arrow.
Old 2nd February 2012, 05:38 PM   #4
You also said you replace two of the 6 mosfets in the power supply. Have you checked the rail voltages to the outputs? The side of the supply you replaced the mosfets in may still not be functional even with new mosfets and the rails will be much lower then required for the amp to work properly.
When these fets blow they often take out the gate resistors 3.3 ohm and the gate drivers Q54 and Q46. If this is the case the supply will only have half functionality, and the new fets installed will burn up in most cases due to self enhancement....
Old 2nd February 2012, 06:39 PM   #5
I buy my tip102/107 from mouser since their close to me (14miles away) but I might have to try arrow, mouser want 1.50 each for STP or TI.
I have not powered up the amplifier since Q55 and Q59 are out of the board, or could I try powering it up to see if I get power from the right channel?
I powered it up once I replaced all 24 TIP102/107 transistors and it played but I believe it was both channels that were distorted (unless my dumbass run it bridge, then there's no way to tell which channel was distored and low).
If the FEB board fail how could I check it or should I replace all the parts on it? If its cheap I rather pick one up from jandrelectronics.
Old 2nd February 2012, 06:42 PM   #6
yeah i replace just two because I broke them off accidently. I purchased them new and never thought if it matter or not if they were mismatched, I know the tip102/107 all have to be from the same run/manufacture date.
So your saying put the board back in chassis, and check rail voltage? What should it be at?
Old 2nd February 2012, 06:58 PM   #7
Are the emitter resistors on the board correct? On schematics it calls for .27 2watt but on the board it looks like red, violet, gray then gold which means 2,700,000k ohms LOL am I right or wrong? They look like they were replaced at one time but looks very proffesionaly could pass for factory.
edit: LOL okay I looked around for gut pics and looks like those are correct resistors.
Old 2nd February 2012, 08:09 PM   #8
The emitter resistors are the correct ones for the amp. I would check each of them to make sure they are all in spec. As I said before they blow open like fuses do when the outputs short out.
Jaime can usually supply you a new FEB board, and all the parts used on them if you want to repair the FEB. I would email him and see what he has on hand and go from their. It is quicker just to replace the FEB if he still them in stock, and since you plate is full repairing this amp perhaps the cost of new FEB's would be offset in time savings. Chances are that both boards are defective at this point.
Old 2nd February 2012, 08:23 PM   #9
I'll get two from him, keeping my fingers cross and hopefully he as two or can let me know how to test them.
This amp is a real PITA, am repaired a few amps (5002, JL 500/1, kicker dx700, xt1600.2, a flat screen with a blown power supply, even a remote control for a new car lol) so am kinda experience, just wish I could learn more and more.
Thanks guys for the help, I'll keep ya'll posted if JandR come through.
1moreamp- what exactly is the value of those resistors? Because I doubt their 2,700,000k ohm more like .27ohm right? Because on board they read about .8ohm and I understand I cannot test them on board becasue of the way their in circuit. I'll remove them later on today (am away from the pc right now) and post results later today. Thanks.
Old 2nd February 2012, 09:23 PM   #10
I'm working (slowly) on a REF700s with a blown power supply- I hope to make some progress on it over the weekend. The emitter resistors on mine are .27 Ohm / 2 Watt.
Trafo bad, or am I bad caxxxxxx Chip Amps 24 3rd May 2011 08:56 AM
Schematic for a Soundstream 700SX kds9591 Car Audio 2 11th November 2008 03:40 AM
schematic for soundstream 700sx shallowfu Car Audio 24 9th July 2007 11:46 PM
Page generated in 0.11957 seconds (83.56% PHP - 16.44% MySQL) with 10 queries
