Go Back   Home > Forums > General Interest > Car Audio
Old 5th February 2012, 07:58 PM   #21
There should be only one capacitor behind it. In this amp, it's black.
Old 6th February 2012, 12:19 AM   #22
Yusef71 is offline Yusef71  United States
I've replaced that capacitor, still no change. Any more ideas as to what could have gone wrong ?
Old 6th February 2012, 06:29 AM   #23
No change from what? You stated that it started working properly. How have the voltages changed (or remained the same)?
Old 6th February 2012, 08:20 AM   #24
I mean, the amplifier still turns on and off sporadically. The early post I meant to say that it turned on, but, it did not remain turned on for long. I apologize for any misunderstandings.
Old 6th February 2012, 04:41 PM   #25
I know of nothing that can drag the voltage down on one end of the large resistor if the large transistor is out of the circuit and the capacitor is not defective. Are you sure that there are no solder bridges anywhere on the board?
Old 7th February 2012, 10:04 AM   #26
I thoroughly looked for any solder bridge, I found none. Could the toroidal power transformer have a short with in it's windings ? It also heats up abnormally as does the large power resistor.
Old 7th February 2012, 08:59 PM   #27
What is the DC voltage across each of the two resistors indicate by the arrows in the attached photo.
You need to measure the voltage when the large resistor is getting hot. I'm assuming that the large transistor is still out of the circuit. If it's not, remove it.
Old 8th February 2012, 11:17 AM   #28
The attached photo showing the two resistors is missing in your post, could you please re-post them ?
Old 8th February 2012, 04:30 PM   #29
See attached.
Old 10th February 2012, 10:21 PM   #30
I've measured the voltage at both of those resistors. The voltage measurements fluctuated between 2.57 V to 3.57 V. Note, the large resistor remained hot during all the measurements.
to mr perry babin and anyone who can answer this question on repair russdeanlee Car Audio 9 27th December 2011 08:38 AM
Orion 225-HCCA av8rdav Car Audio 7 7th September 2008 05:50 AM
Perry Babin ORION 225 shallowfu Car Audio 8 17th October 2006 05:14 PM
Schematics for Orion HCCA 225 D.R. tobias_svensk Car Audio 1 3rd April 2005 07:46 PM
Page generated in 0.10001 seconds (79.01% PHP - 20.99% MySQL) with 11 queries
