eliminating pop sound when using accessory acc as remote wire for amplifier
Old 31st January 2012, 05:34 AM   #1
russdeanlee is offline russdeanlee
Default eliminating pop sound when using accessory acc as remote wire for amplifier
pop sound from speaker when i turn off car, the remote wire i'm using is from the accessory (ACC) because the factory headunit doesn't have a remote out i probed all the leads on the back to no luck so my only option was to use the acc or add a turn on switch. is there a way to remove this pop sound if the rca isn't plugged in it doesn't make that pop sound it only makes it from the rear speaker. it might be because of a cheapy line out converter i'm using for the rear line out converter because this isn't happening to the front line out converter.
Old 31st January 2012, 05:46 AM   #2
seankane is offline seankane  United States
seankane's Avatar
You should be able to purchase a relay that can give you a turn on delay or a soft turn on.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 31st January 2012, 07:06 AM   #3
i don't have a turn on pop only a turn off pop from using the acc for the remote wire because the stock head unit doesn't have a remote out i tried probing for it but no luck. is there anything i can do to get rid of that pop when turning off car
Old 31st January 2012, 07:10 AM   #4
Mote is offline Mote  Estonia
Whats the difference between 12V from remote and 12V from ACC?
Tools: Perrys tutorial, C1-76 o-scope, Weller WHS40, Mastech MAS830L multimeter, Mastech MY6243 LC meter, 16A supply
Old 31st January 2012, 07:19 AM   #5
seankane's Avatar
Good question Mote. Alot of amps have special circuitry to ensure "soft" turn on and turn off to eliminate popping. Maybe it is an internal problem with the amp???
Old 31st January 2012, 02:31 PM   #6
Perry Babin is offline Perry Babin  United States
Do you read 6v DC on all four wires feeding the rear LOC?
eliminating pop sound when using accessory acc as remote wire for amplifierHide this!Advertise here!
Amplifier making pop sound comasus Solid State 20 19th October 2011 05:48 PM
JTD Audio: Amplifier & Accessory Modules. JTD Audio Vendor's Bazaar 1 22nd August 2011 11:08 AM
eliminating pop on power up? darkczar Chip Amps 6 1st April 2010 05:58 PM
'POP' sound when unit is turned off coki Car Audio 5 10th September 2007 07:56 AM
Eliminating capacitor in amplifier series feedback loop Hennie Solid State 17 13th December 2004 11:26 AM
Copyright ©1999-2017 diyAudio
