Go Back   Home > Forums > General Interest > Car Audio
Old 30th January 2012, 09:47 PM   #1
Default Kicker 350.2
Im only getting 4.37 volts on pins 8 and 11 of the 494
Any ideas?
Old 30th January 2012, 10:15 PM   #2
What about the rest of the pins? Most times 8,11 are tied to +12 not always. Depends if they sink or source. 4.37 seems correct if you have a square wave on them.
Old 31st January 2012, 01:22 AM   #3
8 and 11 are tied to the + 12 vots so there is something wrong since i only have 4 volts on pins 8 and 11
Old 31st January 2012, 03:47 AM   #4
What do you have on all the pins?
Sent from my Punch 60.2
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 31st January 2012, 04:04 AM   #5
TL494
Pin 1:0.76
Pin 2:2.69
Pin 3:0.06
Pin 4:0
Pin 5:1.03
Pin 6:2.30
Pin 7:0
Pin 8:3.93
Pin 9:1.72
Pin 10:1.49
Pin 11:3.99
Pin 12:5.02
Pin 13:3.99
Pin 14:4.02
Pin 15:4.00
Pin 16:4.37
I also noticed Q1 has been meesed with at some point Its a B694..
Does anyone know which way it faces towards the transformer or away from it ??
Old 31st January 2012, 01:36 PM   #6
Trace pin 12 back and find out why 12V isn't present or lift it and see if it returns.
Old 31st January 2012, 02:26 PM   #7
Anyone have a schematic for this amp ?
Or that can point me in the right direction i checked alot of stuff but i must be missing something since i dont get 12 volts on the 494 no lights no nothing
Old 31st January 2012, 02:31 PM   #8
Ok Pin 12 connects to the middle leg of a B694 transistor..
Heres the voltages i get on the B694
Pin 1:13.92
Pin 2:0
Pin 3:13.89
Old 31st January 2012, 02:51 PM   #9
If that transistor isn't shorted from 1-3m follow the circuit back from pin 3. IT should go through a resistor and to an NPN transistor. Post the voltage on that NPN transistor.
Old 31st January 2012, 02:57 PM   #10
What connects to pin 1? That should be pulled low, maybe by another transistor?
$50 Hammond 373BX 187VA 350-0-350 Transformer maxseeley Swap Meet 0 28th November 2011 05:24 AM
Studio 350 diban Solid State 6 27th April 2010 12:07 AM
Help Help!!! 350.5 bebo60 Pass Labs 1 25th January 2009 12:32 PM
x-350 and x-250 help scott262 Pass Labs 9 27th November 2008 07:53 PM
Copper going away at 350° ? Bernhard Parts 8 12th May 2008 07:28 PM
Page generated in 0.09419 seconds (85.62% PHP - 14.38% MySQL) with 10 queries
