Go Back   Home > Forums > General Interest > Car Audio
Old 24th January 2012, 09:53 PM   #1
Question Precision Power Gen.1 vs "Art series"
Hello,
I was wondering if there are any oldschoolers out there for some opinions and thoughts on real oldschool PPI amp vs amp.I know the first gen M,AM,and pro mos have a higher damping factor than the triangular/round "Art Series".But I am wondering power,s.q.,reliability,and build quality even though the .2's should have still been Arizona made what you think about them in comparison?
Thank You for any input/opinions in advance
Old 26th January 2012, 11:39 AM   #2
Check diyma, whole oldschool subforum there
Old 26th January 2012, 02:57 PM   #3
Thank You for your help.I'll try that.
Old 27th January 2012, 01:07 PM   #4
No worries, Brett aka PPI-Art-Collector will be a fountain of knowledge. FWIW damping factor is a bit of snake oil:
From wiki
"Amplifier output impedance
Modern solid state amplifiers, which use relatively high levels of negative feedback to control distortion, have extremely low output impedances—one of the many consequences of using feedback—and small changes in an already low value change overall damping factor by only a small, and therefore negligible, amount.
Thus, high damping factor values do not, by themselves, say very much about the quality of a system; most modern amplifiers have them, but vary in quality nonetheless. Given the controversy that has long surrounded the use of feedback, some extend their distaste for negative feedback amplifier designs (and so a high damping factor) as a mark of poor quality. For them, such high values imply a high level of NFB in the amplifier.
Tube amplifiers typically have much lower feedback ratios, and in any case almost always have output transformers that limit how low the output impedance can be. Their lower damping factors are one of the reasons many audiophiles prefer tube amplifiers. Taken even further, some tube amplifiers are designed to have no negative feedback at all."
From Andy Wehmeyer, product manager at Harmon Kardon and another forum gem:
"This is the best explanation I've ever read and it's absolutely true.
Damping Factor: Effects On System Response — Reviews and News from Audioholics
It's pretty close to what RC says and it's the reason that CEA2006 indicates "output regulation" and "Effective damping factor".
The Crown paper is misleading. Anytime you read a supposedly scientific paper that starts out by indicating that a device "has a mind of its own", you can pretty much chalk it up to the work of a marketer who is trying a last ditch effort to sell someting that's been debunked.
The point is that high amplifier output impedance does have an effect on system response, but its effect is on the frequency response because an amplifier is a constant voltage source and its power output is regulated by the load. The output impedance is in series with the load. It's not much of a factor at resonance where the speaker's impedance is high, but it can be a factor above resonance where the speaker's impedance is low. The output impedance has to be pretty high for this to happen, though. For a 4-ohm speaker, the output impedance would have to be 4 ohms to reduce the midrange by 3 dB. Floyd Toole says low Q peaks and dips are audible at .5dB, so something like a half ohm might be audible.
It the amplifier's output impedance is not a factor in cone control unless the output impedance is ridiculously high--several ohms. It would be pretty difficult to find a car audio amplifier with an output impedance that high. No, not pretty difficult. Damn near impossible. Even .5 ohms is completely out of spec for any amplifier that uses transistors as output devices."
Old 29th January 2012, 06:51 PM   #5
Thank You very much for the info!I'll check out the PPI Art Collector and see what he thinks.Thanks Again!
Old 30th January 2012, 09:38 AM   #6
No worries, let me know your username for diyma and we can chat there too
Old 30th January 2012, 03:33 PM   #7
Same name on there too.Send me a message.Thanks!
Old 31st January 2012, 03:02 PM   #8
Same name for me too
Old 1st February 2012, 08:13 AM   #9
all i can say, is that the bigger differences lies in the application of the individual lines and the processing. there is some efficiency difference, but, from what i've seen is that the arts were designed for performance at higher imp. loads, where many others were rated at higher loads, but mostly higher current geared. although, there were both types throughout, those are speaking mostly of the more popular models. as for reliability, designs didn't really go backwards while us made, but the newer models had the stupid molex plugs, and the older ones had undersized wire and harness plugs, etc. either way, i would say that wiring/termination was the single common downfall of all the old school ppi's. -my$.02
Old 1st February 2012, 05:17 PM   #10
Thank You!That is what i was looking for.Great $.02!That is one reason I like that you can get 4 gauge power/ground & bigger speaker wire plugs for the .2's and stuck with the molex and 14 or 12 gauge power/ground on the gen.'s!And yes application plays a factor..
Tahnk You
Question about "old" technology: the wiiide baffle of the Boston Acoustics "A" series River757 Multi-Way 27 9th November 2011 01:06 AM
Precision Power a1200.2 art series blacknred2010 Car Audio 2 19th August 2011 11:54 PM
Very hard to find - Brand Name: "power" - Power Amp APK/APX series schematics wanted tiefbassuebertr Solid State 2 21st March 2011 11:09 AM
Precision Power Art Series A600 MOER Solid State 0 25th February 2011 08:57 PM
PPI ART Series a404 "v" PPI Powerclass pc450 swap chemhaz Car Audio 2 21st November 2008 02:23 PM
Page generated in 0.10857 seconds (80.41% PHP - 19.59% MySQL) with 10 queries
