hello, im currently having some issues with an Eclipse DA6213. I was hoping some one could help me trouble shoot it. The amp powers on, but the green light does not come on and does not produce any audio output. Ive checked on the board and everything appears to be in tact and in good standing. Fets look good, nothing looks out of the ordinary. Any help is appreciated.
Thanks -Rob |
#2 |
got a picture?
#3 |
I shorted out a power supply fet by mistake last night. But even prior to that the green light never came on and had no audio output. You can see it , the second one in on the top right hand side.
#4 |
Ive checked the voltage on the rails by the power / ground terminals, all is well there, however when i check the rails for voltage by the power supply fets, i dont get any reading
#5 |
Do you read 0, 12 and 0v on the legs of all of the power supply FETs?
Have you checked the output transistors to see if any are shorted?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#6 |
i checked the fets and they did read 0-12-0v on all untill i shorted one out. Whats the easiest way to check the output transistors ?
#7 |
remove the fet u shorted .power supply is not starting unit will not power on
what chip does it use for the psu . |
#8 |
this amp uses NEC K3057 . I wasnt able to find these anywhere. Is there a good substitute to use ?
#9 |
its a 2sk3057
check the psu chip what is the part number on it u don't have and gate voltage |
#10 |
Do you still read 0, 12, 0 on the power supply FETs?
| eclipse 32430 Amp repair | 91h22a | Car Audio | 8 | 27th May 2011 09:12 PM |
| Eclipse DA6213 repair ? | SIRDRINKSALLOT | Car Audio | 7 | 17th January 2009 12:48 AM |
| Eclipse manual help please | rader | Car Audio | 0 | 29th October 2006 03:06 PM |
| Eclipse | Brian Donaldson | The Lounge | 5 | 28th October 2004 08:32 PM |
| Eclipse? | Larr_e_boy | Multi-Way | 0 | 7th June 2001 02:41 PM |
| Page generated in 0.08807 seconds (80.84% PHP - 19.16% MySQL) with 11 queries |
