I have a P300 the new style that is killing my battery.
I have a direct tone from power and ground. I am certain the amp is pulling a constant load. I opened the amp up and one of the heat sinks is toasted. IRFP064N The amp still works fine, just drains my battery. Anyway... I know the blown heat sink can cause the direct short. is there something else I should look at. When the bad heat sink was still in the amp, I could test for tone on the main power and ground leads of the amp. It would get a pulsating tone. Seems strange to me. The tone would go on and off. Now... I removed the blown heat sink, I have tone for a few seconds then it quits. I guess the amp is doing something. I totally don't understand why the tone would come and go... I basically have no idea what I am doing. I know just enough to know the amp was the issue. Seems like it will be easy to replace the bad heat sink. So.. the question is... Should I test anything to look for the short? |
#2 |
For clarification, the heatsink is the large piece of aluminum that the semiconductors are clamped to.
The IRFP64 is an FET and is likely in the power supply. IF one FET in the supply has failed, the amp is likely performing very poorly. It's possible that it's drawing current when the amp is off. It's not common but possible. When the meter reading is below a certain threshold, it will produce a constant tone. After the meter charges the capacitors beyond that threshold, the tone will stop. Is this a P300-1? If you replace the FET, you need to replace both of them. You also need to confirm that the gate resistors are within tolerance. Since you're new to amp repair, read the entire basic amp repair page (link in sig line).
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Mistake on calling it a heatsink. It is the Mosfet or resistor.
Yes, it is a P300.1 I am 100% certain it pulls constant power when on or off. Pulls 4 amps when car is turned off. It is not my wires it is the amp. Changed the amp and the drain stopped Surprisingly the amp seems to work very well. I bought it used. I am only pushing a P2/12 "When the meter reading is below a certain threshold, it will produce a constant tone. After the meter charges the capacitors beyond that threshold, the tone will stop. " Ok, that makes sense. And then when the blown resistor was shorting out it would discharge the capacitor, thus starting the tone again. "If you replace the FET, you need to replace both of them. You also need to confirm that the gate resistors are within tolerance." There are actually 6 of them, total. I will read the guide. I think this is an easy fix, everything works. I just need to stop the drain on the battery. |
#4 |
I don't see anything on a 300.1. Please post a photo of the inside of the amp.
| QED P300 service manual ..very long shot butI'm, stripping my dads QED P300 to get my | Fivetide | Parts | 2 | 8th August 2011 07:40 PM |
| Rockford P300-1 | brandes.cm | Car Audio | 1 | 19th February 2010 02:56 PM |
| Direct (or almost direct) replacement for Morel MW144? | mr_push_pull | Multi-Way | 1 | 19th April 2009 04:43 PM |
| trouble with a PSAudio p300 | Joseph0 | Solid State | 1 | 21st July 2005 12:27 PM |
| accuphase p300 II | reinhard | Solid State | 1 | 14th November 2004 12:37 PM |
| Page generated in 0.08396 seconds (76.76% PHP - 23.24% MySQL) with 10 queries |
