hi all
Am trying to find out the vlaue of a resistor (RP18).It is connected to the first leg of A1220A-y transistor(QP5) and the center leg of c2316 transistor(QP3) This is in the power supply.THis amp came in with capacitor (c2) and resistor RP18 burnt. |
#2 |
If one end connects to the B+ terminal of the amp and the collector of the 1220 connects to pin 11/12 of the 494, it's likely 4.7 ohms.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
I put in a 4.7 resistor and i replace the cap.Amp power up and plays good audio.The power supply FET (FQP50n06) have 0.5v on the gate leg,is that normal? Isn't it suposed to be about 4.*v?
#4 |
If the supply is regulated, the voltage at the gates may be very low. As long as the rail voltage is correct and the voltage on pins 9/10 and the gates is close, it's likely OK.
#5 |
I run it at full power and it is working good
Thanks for the help |
| DHD NTX2960 | ian33 | Car Audio | 1 | 14th October 2011 05:36 PM |
| dhd ntx 6211 burnt transistors | ian33 | Car Audio | 0 | 27th April 2011 06:15 PM |
| Parts Info | thomasfw | Solid State | 2 | 12th February 2009 01:57 PM |
| DHD should repair? | Solosound | Car Audio | 5 | 9th November 2008 07:39 PM |
| NTX Flat Panel speakers | Iceshack | Multi-Way | 2 | 9th February 2003 10:15 PM |
| Page generated in 0.08507 seconds (72.63% PHP - 27.37% MySQL) with 11 queries |
