Ringing on gate signal
Old 19th April 2012, 10:23 PM   #21
brandes.cm is offline brandes.cm  United States
Pulled the caps they check fine.
+12 supply has the ringing as well, rectifier maybe?
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 20th April 2012, 08:49 AM   #22
Perry Babin is offline Perry Babin  United States
I doubt that it's the rectifiers but it could be. I'd suggest sliding the two 330 ohm resistors driving pin 2 of the two opto-couplers off of the pads and then rechecking the 12v.
If it's clean, compare the readings from the two opto-coupler output pins. IF they read the same, I'd suggest pulling the outputs. Then re-check the drive circuit. Load the gate/source with a 1000pf capacitor and compare the high and low side. You'll have to ground the output inductor on the FET side of the inductor to get a clean drive signal.
With these amps, I've found it's almost always easier to confirm that the drive circuit is good. Then replace the outputs.
Old 2nd January 2013, 10:23 AM   #23
bobik34 is offline bobik34
Did you resolve the problem? I have the same problem oscilation on gate from positive voltage side and when I measure dc voltage on output (use multimeter) i see about 2.5v but when i connect scope i see oscilaton (sine wave 125khz). Meybe you now what integrated circuit are on driver board? first is op-amp to generate frequency signal tl082 second is comparator lm319 and two more... what are the other ic?
Ringing on gate signalHide this!Advertise here!
mmats d200hc and earthquake d2 gate drive signal spooney Car Audio 1 24th June 2011 03:35 AM
Gate capacitance and gate charge rtarbell Parts 1 22nd January 2007 05:11 PM
Ringing midrange JP Haggar Multi-Way 7 17th April 2006 02:33 PM
best way to generate Gate-Drain or Gate-Source short in electret capsule JFET? capslock Parts 2 27th September 2002 08:07 AM
Acoustic ringing? grataku Solid State 1 15th March 2001 04:55 AM
