AMP WILL POWER UP AND PLAY BUT IT PLAYS DISTORTED AUDIO THRU ALL 4 CHANNELS..
IT ALMOST SOUNDS LIKE STATIC KINDA LIKE AN AM RADIO.. ALL OUTPUUTS TEST FINE ALL EMITTER RESISTORS ALL CHECK FINE ALSO.. ANY IDEAS ?? |
#2 |
Does it use panel mounted or circuit board mounted RCAs? Sometimes the circuit board mounted RCAs tend to break the solder joints.
#3 |
RCA shield detached from the board?
| Fluke 10 | Ramsey BS-601 | Topward 8102 | RS MiniAmp | Pyramid PS-15KX | DieHard |Big A$$ Resitor | |
#4 |
I dont know why i didnt catch it earlier since ive fixed alot of fosgates But you guys were correct it was the rca shield ground
#5 |
I notice that happens a lot on circuitboard mounted RCA's. Had to do the same thing to my head unit.
#6 |
The old rockford punch amps have some pretty thin RCA shield connections. Combined that with solder joints not allowing flexibility right at the RCA shield's weakest point, plus often the screw missing which holds the RCA in place, and youve got an eventual fault.
| Rockford fosgate 4.6 X | mike49504 | Car Audio | 14 | 28th May 2011 03:35 PM |
| Fosgate Punch 800 a4, diagram needed | camoandbee | Tubes / Valves | 0 | 13th April 2011 06:33 PM |
| Rockford Fosgate BD1000 | mike49504 | Car Audio | 1 | 9th January 2011 11:37 AM |
| Rockford Fosgate | dtisme | Car Audio | 1 | 5th October 2010 11:39 PM |
| Rockford Fosgate 600.5 | mike49504 | Car Audio | 68 | 20th March 2010 05:32 PM |
| Page generated in 0.07363 seconds (73.00% PHP - 27.00% MySQL) with 10 queries |
