It takes me to a support page every time I hit send. Moctezuma028@gmail.com. I found the. SM for the pdx 1000. Would you like me to send it to you?
Ok, i got this amp from a friend. I don't know how it went out but when i opened it all the output fets were toast. The only thing ive done so far is remove them. When power is applied the blue l.e.d's light up and one switches to red. The gate leads are getting 13 volts but i didn't pick up a pulse.
IC9802 voltage
Pin 1: .016
pin 2: .003
pin 3: .018
pin 4: .001
pin 5: 0
pin 6: .119
pin 7: 9.0
pin 8: .119
ic9701
Pin 1: 0
pin 2: 4.4
pin 3: .098
pin 4: 3.64
pin 5: 1.68
pin 6: 3.53
pin 7: 0
pin 8: 9.06
pin 9: .016
pin 10: .016
pin 11: 9.06
pin 12: 9.06
pin 13: 5.04
pin 14: 5.04
pin 15: 5.04
pin 16: 0
q9701 reads
pin 1: .016
pin 2: 5.04
pin 3: 5.00
IC9802 voltage
Pin 1: .016
pin 2: .003
pin 3: .018
pin 4: .001
pin 5: 0
pin 6: .119
pin 7: 9.0
pin 8: .119
ic9701
Pin 1: 0
pin 2: 4.4
pin 3: .098
pin 4: 3.64
pin 5: 1.68
pin 6: 3.53
pin 7: 0
pin 8: 9.06
pin 9: .016
pin 10: .016
pin 11: 9.06
pin 12: 9.06
pin 13: 5.04
pin 14: 5.04
pin 15: 5.04
pin 16: 0
q9701 reads
pin 1: .016
pin 2: 5.04
pin 3: 5.00
using this data sheet black probe on amp terminal ground and red probe to test voltages are as follow DTA124EKA pdf, DTA124EKA description, DTA124EKA datasheets, DTA124EKA view ::: ALLDATASHEET :::
q9701
pin 1: .015
pin 2: 5.04
pin 3: 5.00
q9701
pin 1: .015
pin 2: 5.04
pin 3: 5.00
- General Interest
- Car Audio
- alpine pdx 4
