I got this amp in with all of the power supply fets blown and 3 outputs that were bad..
I replaced the power supply fets and removed all outputs.. Tested for DC on the speaker terminals with all outputs removed i get 0.01 volts .. So i started putting 2 outputs in at a time.. With 2 outputs in the amp i still get 0.01 volts ... So i put 2 more outputs in the amp and now i get 40 volts of rail on the output terminals measured directly across the speaker terminals.. Do i need to put all of the outputs in it to see if the DC goes away or do i have another problem ? |
#2 |
If you installed both high-side and low-side FETs, it likely has a defective drive circuit.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Is this a type-2 Class-D? IRF30n20d outputs? Check the MPSAxx BJTs on th driver board. make sure the fan is working right also.
| Fluke 10 | Ramsey BS-601 | Topward 8102 | RS MiniAmp | Pyramid PS-15KX | DieHard |Big A$$ Resitor | |
#4 |
It uses the FB31N20d's For the outputs But the amp has no driverboard and no fan..
#5 |
The driver board is in the black box near the output filter inductors. It's not repairable and, the last time I checked, not available from the manufacturer.
| planet audio bb2400.1 | bdgf2004 | Car Audio | 76 | 29th April 2012 06:01 PM |
| Planet Audio bb2400.1 | mupto | Car Audio | 7 | 24th September 2011 10:20 AM |
| Planet Audio PA2250D | spooney | Car Audio | 24 | 15th February 2011 04:05 PM |
| Planet Audio ZR300.4 | o. l. t. | Car Audio | 25 | 24th May 2010 03:46 AM |
| Planet Audio amp | rader | Car Audio | 3 | 7th November 2006 08:50 PM |
| Page generated in 0.07354 seconds (76.95% PHP - 23.05% MySQL) with 10 queries |
