Question on this amp: Should all 8x IRF3710 outputs have some rail voltage on them? I'm only finding half with +54v. This amp only has positive rail voltage.
This amp is kinda similar to a Mmats amp, but this being the generic version. I've seen other generic types such as Slugger and a few. The board says designed by D.R.Ecker, CE of US Amps. It uses the HIP4080 driver. I got this amp in with one of the output chokes desoldered/damaged PCB, and 2x IRF3710 shorted.
| Fluke 10 | Ramsey BS-601 | Topward 8102 | RS MiniAmp | Pyramid PS-15KX | DieHard |Big A$$ Resitor | |
#2 |
All (as far as I know) of the 4080 based amps have only one positive rail for the output transistors. Half of the outputs have their drains connected to the positive rail. The negative rail is ground. The source legs of the other half of the outputs connect to ground. The remaining drains sources are connected together (in two isolated groups) and swing between ground and the positive rail.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| Amp for a POD XT? | Aw_De_Oh | Instruments and Amps | 1 | 5th December 2008 01:29 AM |
| Zaph ZD5 vs. Ellam XT | bogey | Multi-Way | 3 | 12th January 2007 09:01 AM |
| Rolling off the Vifa XT... HELP! | fazman | Multi-Way | 1 | 19th January 2006 05:40 PM |
| Vifa XT Combo??? | audioferret | Multi-Way | 0 | 3rd December 2005 05:56 PM |
| 9700 Vs XT | Raka | Multi-Way | 8 | 12th May 2004 12:15 PM |
| Page generated in 0.06157 seconds (68.57% PHP - 31.43% MySQL) with 10 queries |
