Hi there,
I have an amp that is built into a sobwoofer case that I haven't been able to fix. Maybe you guys can help me on you on this one? I have fixed a few amps before, but this particular amp is giving me a hard time. When I received it, both power supply mosfets (IRFZ44N) and four output transistors with one preamplifier transistor were shorted. So, I replaced them, but were unable to find the exact match for the preamplifier transistor B631K, for wich I used BD140 as a temporary replacement. The amp powers up and everything seems to be fine: I get +-35V on the rectifiers and the led is green. However, as soon as I connect it to the speaker, the output transistors and preamps begin to get warm gradually to the point where they are so hot that I have to disconnect the power. I'm using a power supply with a weak current output of about 2A, so I have time to measure voltages before things get critical. I have checked other transistors in the audio section, but couldn't find any more shorts. What do you think? Thanks in advance for you time. Please see the attached pictures for reference. |
#2 |
is it attached to a heatsink during testing?
#3 |
No, it's sitting on my table without heatsink. The limited current output from the power supply doesn't let it get hot quickly. But maybe I should afterall attach the heatsink in order to protect the transistors I installed.
#4 |
What is the DC voltage across the wires that go to the speaker with the amp on but with no input signal?
Have you checked the other driver for leakage (would have to be pulled out of the board)?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 |
Hi Perry,
DC voltage across the wires is 0.39 V. I checked the other driver for shorts in circuit. Do you think I should remove it? |
#6 |
A leaky driver could cause problems and you can't check it for leakage in the circuit.
Do you have a scope? Do the output transistors heat up if the amp is on with no speakers connected?
#7 |
The amp doesn't heat up when the speaker is not connected. The trouble start as soon as I connect it. Unfortunatelly I don't have a scope, so I can't diagnose the amp as thouroughly as I would like to.
#8 |
Do all of the outputs heat up or do only 2 (of the same part number) heat up?
Check the driver.
#9 |
I removed the driver that I didn't replace before, but it isn't shorted when checked out of circuit. I turned the amp on briefly with the speaker connected, and the outputs are still heating up. Two A1694 transistors dissipate most heat.
#10 |
Is it leaking (not shorted but conducting in a way that it should not)?
The heating is because those transistors are passing the DC to the speaker.
| Amplifier for subwoofer | oon_the_kid | Subwoofers | 8 | 10th February 2011 03:26 PM |
| Subwoofer Amplifier | cloo24 | Solid State | 2 | 30th November 2010 02:40 PM |
| Subwoofer amplifier please | at1receptor | Class D | 0 | 22nd February 2008 11:54 AM |
| subwoofer amplifier help | at1receptor | Solid State | 37 | 18th July 2007 01:51 AM |
| Amplifier for subwoofer(s) | HoMzE | Solid State | 1 | 14th November 2003 02:51 PM |
| Page generated in 0.09973 seconds (79.34% PHP - 20.66% MySQL) with 11 queries |
