Go Back   Home > Forums > General Interest > Car Audio
Old 13th January 2012, 02:23 AM   #1
Default Another Rockford T1500.1bd issue
I seem to be getting my behind whipped by another T1500. This amp originally had 1 output fet shorted that I could tell. I replaced the channel and powered up only to blow another fuse. I checked all components on the audio side and everything seems ok. I powered up with a two ohm resistor and something buzzes for a few seconds, and then pulses, it sound like it's coming from the transformer but I am not positive. Also I noticed the power supply fets read around .70 volts between the drain and source on diode check, which seems low but none are defective. I have never heard an amp make these noises so any insight would be appreciated. Also after removing all of the p.s. fet's to check them outside the board, one was shorted. All were replaced.
Old 13th January 2012, 02:32 AM   #2
timwebb is online now timwebb  United States
u checked the drive transistors and gate resistors?
Old 13th January 2012, 03:04 AM   #3
Yes
Old 13th January 2012, 03:06 AM   #4
u try twisting on it to see if the voltage change? it could be a short.
Old 13th January 2012, 05:00 AM   #5
whenever i set rockford power series (non-elite) gains on the scope, everytime the signal level clips on the scope using a -10dB 40hz overlap track. i hear the buzzing sound. i've experienced it with all non-elite power series that sometimes even without a scope, you can tell the amplifier just clips @ -10dB 40Hz signal once you hear the buzzing sound. back down a little and the buzzing sound goes away.
maybe the gain pot is messed up?
Old 13th January 2012, 06:21 AM   #6
Only connect the remote and the ground (no B+). What is the DC voltage on each of the power supply FET gate legs?
Black probe on amp ground.
Old 13th January 2012, 01:56 PM   #7
It is 12v, I forgot to mention that the voltage only drops after the remote is applied
Old 13th January 2012, 02:00 PM   #8
I don't have any audio signal going to it, the guy I bought it from told me that it would buzz and put out distorted audio but when I checked it, it just blew fuses. If the gain pot was messed up it still should not cause the fuse to blow right? I thought the sound would just be distorted and, or humming?
Old 13th January 2012, 03:13 PM   #9
perry can shed light on this. i have his dvd and i'm also in the process of learning.
but i tried awhile ago, even the t6004 makes the buzzing sound inside the amp when -10dB 1kHz overlap signal is going through the amp. and with the overlap, the gain pot is set higher than when using 0dB. but yours doesn't have signal input yet it buzzes so it could be different.
Old 13th January 2012, 03:37 PM   #10
If you have 12V on the gate leads that would tell me the 3525 or TL494(which ever it uses) is not running. What are the voltages on that part?
Rockford T1500-1bd brianluing Car Audio 2 12th January 2012 04:37 AM
Rockford 1500-1bd impactair Car Audio 62 8th January 2012 11:27 PM
RF T1500-1BD brandes.cm Car Audio 12 12th November 2011 08:43 PM
Tips on fixing my Rockford P1000-1bd jamesnail Solid State 8 30th January 2010 09:56 PM
rockford p600.1bd amp Cal Weldon Car Audio 0 7th September 2009 05:47 AM
Page generated in 0.09726 seconds (78.21% PHP - 21.79% MySQL) with 10 queries
