diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Overheated Amplifier (http://www.diyaudio.com/forums/car-audio/204389-overheated-amplifier.html)
carshateme 12th January 2012 09:13 PM
Okay I made an amp rack for two of my amplifiers. One amplifier was a PPI PC2100. The other is a HIF2000D.
I had the PPI amplifier on the bottom rack and the HIF on the top. I THOUGHT that the port air from my subs would cool down the PPI amplifier by pushing air pass the amp. I was wrong. Noob mistake. Now its distorting out my sounds...crackling sounds. What component should I look to replace inside the amp to fix it?
I'm a noob at it, but I'm good at repairing electronics, so I just need to know what to look for, where's it's located and such, if pictures are needed, I'll post them.
Perry Babin 13th January 2012 06:11 AM
Do both channels produced distorted audio?
Have you confirmed that the speakers are still in good working order?
Have you checked the voltage at the power/ground/remote terminals to confirm that all are at or above 12v?
carshateme 14th January 2012 10:36 PM
Both channel are outputting disorted audio. I checked the ground. It is still good. I havent done a volt test yet though. Both speakers work fine. I just need to sell it so it can go towards my infinity interior setup...but I cant sell it broken
Resources saved on this page: MySQL 18.75%
