I got this amp with blown power supply fets -FQP50N06 i replaced them with IRFZ44's..
When powering up the outputs will get red hot only on 1 side of the amp..
I removved them they all tested fine.. So i took the drivers for the outputs out and they also tested fine...
I replaced the drivers for the outputs just incase they were defective and were testing fine..
The orginal drivers are B647 and D667
I replaced the D667 with a C3228 and the B647 with a A1275..
Power the amp up and they still get red hot...
Any ideas ?
Any ideas ?
Assuming that the positive terminal for this channel is used for bridging, having 0 ohms to the B+ on the negative terminal would be a problem. It would seem to indicate that the amp has a shorted transformer. Connect the meter to those two terminals and twist the transformer. Does that eliminate the short?
- General Interest
- Car Audio
- Power Acoustic PS2-2200
