Go Back   Home > Forums > General Interest > Car Audio
Old 12th January 2012, 01:26 AM   #11
When all 6 are in the circuit are those the only 3 that get hot? Or do all 6 in that channel?
Old 12th January 2012, 01:27 AM   #12
All 6 get hot
Old 12th January 2012, 02:02 AM   #13
If you short legs 1 and 2 of Q104 (bias transistor), do the outputs still get hot?
Old 12th January 2012, 02:07 AM   #14
Yes
I was doing some testing and not sure if its suppose to be like this or not but the channel thats giving me problems I have 00.2 ohms between the negative speaker terminal and the B+ terminal
Old 12th January 2012, 02:10 AM   #15
Check the bias transistor. Confirm that it has two good junctions.
Old 12th January 2012, 02:13 AM   #16
NO Rca's were unpluged
Bias transsistor has 2 good junctions
Old 12th January 2012, 02:22 AM   #17
Assuming that the positive terminal for this channel is used for bridging, having 0 ohms to the B+ on the negative terminal would be a problem. It would seem to indicate that the amp has a shorted transformer. Connect the meter to those two terminals and twist the transformer. Does that eliminate the short?
schematic of Phonic PWA 2200 power amp? richi Solid State 0 4th October 2011 09:27 PM
2200 uf 6.3 v Black gate for 2200 uf 16 vdc max29 Analog Line Level 7 7th November 2007 08:51 AM
NAD 2200 power supplay help needed cypher Solid State 16 31st March 2007 09:40 PM
Audio Alchemy ultraDac/dacman power supply ps2 endovision Digital Source 1 7th March 2005 12:58 AM
ps2 power supply moi Everything Else 11 16th July 2003 10:24 AM
Page generated in 0.08209 seconds (75.96% PHP - 24.04% MySQL) with 11 queries
