pioneer rca blown - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 10th January 2012, 12:29 PM   #1
rrae is offline rrae  Norway
Default pioneer rca blown
Hello,
I have question, the the speaker amplifier IC have the same ground with RCA? The situation is that RCA shield is blown and have no output from speaker terminals at headunit. 6900IB
scope,dmm,cd
Old 10th January 2012, 07:19 PM   #2
The ground is the same for both the internal amp and the RCAs but when the RCA shield ground is burned, it doesn't affect the output of the internal amplifier.
Old 24th January 2012, 08:33 PM   #3
HU came with blown rca shield and burn trace from D706 to C235/AGND. damage was done by fail'd amp, possible. There is no sound output from unit outputs. Need some advice. PAL007C might be blown? What should i check first? deh-p6900ib
scope,dmm,cd
Old 24th January 2012, 10:58 PM   #4
Does the remote output work?
Do you have ~6v on each of the 8 speaker wires of the head unit?
Old 25th January 2012, 06:21 AM   #5
If i remember correctly - there wasnt enough voltage on remote - 8v
scope,dmm,cd
Old 25th January 2012, 06:26 AM   #6
Measure it again.
Old 25th January 2012, 07:27 PM   #7
I got 4.66v on remote.
6v on each speaker wire, when meter black probe is on ground terminal.
scope,dmm,cd
Old 25th January 2012, 08:05 PM   #8
I got 4.19v on 22pin - mute pin
scope,dmm,cd
Old 26th January 2012, 01:36 AM   #9
The IC is likely damaged if you only have 5v on the remote output terminal.
Try grounding pin 22 to see if that allows the speaker level output to produce audio.
Old 26th January 2012, 07:03 AM   #10
I had no luck by replacing it with TDA7384A.
scope,dmm,cd
pioneer sa-6500 ii blown fuse 1968vwbug Solid State 6 16th June 2010 10:39 AM
Blown backlight on Pioneer DEQ 99 MikeHunt79 Car Audio 1 23rd July 2009 06:30 PM
Pioneer DEH-P860MP RCA grounding problem Jexx Car Audio 16 13th March 2008 08:11 PM
Pioneer HT receiver... blown channel? infinitesymph Solid State 13 17th February 2008 11:50 PM
PIONEER XV-DV313 blown amp (s/c) Culdy Solid State 0 17th December 2007 03:41 PM
Copyright 1999-2017 diyAudio
