#11 |
Figured I would replace them, but ill check them with a DMM to make sure they still hold the same ohm value. If they do Ill toss them back in. Just seems right to replace parts that smoke up. I'm a mechanic and work on h-60b helos for the navy, so its natural for me to replace parts that look damaged or worn, lol.
#12 |
A bit different type of repair. An amp isn't going to drop out of the air from 10,000ft.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#13 |
Hmm, good point.
Ok, replacing the transistors so heres a pic of it. ![]() Thinking one of these- Digi-Key - IRF540ZPBF-ND (Manufacturer - IRF540ZPBF) or Digi-Key - IRF540PBF-ND (Manufacturer - IRF540PBF) |
#14 |
I'd recommend the non-Z version. It's best to use the original part number unless there is a known reason not to do so.
#15 |
sounds good. I know I am full of questions, but what difference does the "Z" make? I like to understand the parts i replace, mechanic or electric.
#16 |
It's just a different version of the same basic part. In general it performs the same but sometimes minor differences make a big difference (i.e. IRF540N in place of the IRF540 in Rockford amps).
#17 |
Oah, and is there anything else I should check before ordering the parts for this amp and the JL?
#18 |
Replaced the transistors and shes working on bench, so tomorrow I will hook her up and see if theres any problems on putting power through it.
| Memphis 16-st1000d | Componentr | Car Audio | 11 | 11th March 2012 04:57 AM |
| jl 500/1 and memphis 16-mc3004 amp problems. | StillLearning | Car Audio | 5 | 3rd January 2012 02:14 PM |
| Memphis 16-ST1000D | Dr Zeus | Car Audio | 24 | 16th April 2011 03:53 AM |
| Memphis 16-PR1KD | timwebb | Car Audio | 13 | 6th July 2010 10:13 PM |
| Memphis 16-st1000d | mike49504 | Car Audio | 46 | 19th May 2010 07:40 AM |
| Page generated in 0.08863 seconds (79.45% PHP - 20.55% MySQL) with 11 queries |
