PPI A200 wont power up PPI A200 wont power up - Page 2 - diyAudio
Old 9th January 2012, 03:47 AM   #11
Perry Babin is offline Perry Babin  United States
What's driving the base of Q40?
What happens if you remove Q40?
Old 9th January 2012, 10:35 PM   #12
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
Theres a 220 ohm resistor from ground, connected to a 10k resistor, connected to the base of Q40. Between the 220ohm and 10k resistor is a 2n5064 at U4. The cathode (Leg 1) of this thyristor is connected b/t 220ohm and 10k resistor.
I'm not sure if I can test a Thyristor using diode check.
With Thyristor 2n5064 removed
Red on Leg 1 (Cathode)
Leg 1-2: OL
Leg 1-3: OL
Red on Leg 2
Leg 2-1: 0.641 (beeps)
Leg 2-3: OL
Red on Leg 3
Leg 3-1: OL
Leg 3-2: OL
With both of these TO92 transistors removed, and the jumper b/t Pin 8&16 removed on the SG3525, the amp powers and stays powered without flickering, no voltage drop.
The MPSA06 measures good off the PCB. I put it back in (With the Thyrister still out of circuit and the jumper still removed) the amp powers on forever.
I'll trace what this thyrister is connected to after I get back from an errand
Old 10th January 2012, 01:19 AM   #13
The SCR is likely being used as a latch. With DC, if you charge the gate of the SCR, it conducts and continues to conduct until voltage is removed from the other 2 terminals.
Yes. follow the circuit back to see if you can determine what's driving it.
With it out of the amp and everything clamped down, does it produce clean audio into a load up to clipping?
Old 10th January 2012, 01:35 AM   #14
Dr Zeus's Avatar
I think I figured it out. I had noticed the two 50v caps close to the thyristor were a tad loose before, but now they are broken of the board. They may not have been connected up before. I will replace them and glue the new ones down but need to buy these new. I don't think amp is gonna work otherwise.
Old 10th January 2012, 02:41 AM   #15
'Thyristor' is a type of semiconductor that covers multiple components. You have an SCR (a type of thyristor).
Old 10th January 2012, 03:18 AM   #16
Dr Zeus's Avatar
Much to learn
I carefully put a pair of temporary caps in place of the 50v/1000uF units. The temp ones are 50v/2200uF. They are way to big to fit under the cover, but they allowed the amp to power up with all components installed. Time to order-up some of the proper size.
Old 1st May 2015, 05:26 PM   #17
sonus movens is offline sonus movens  Italy
Hi there,
I have a PPI 2200M, dual mono. I have an anomalous absorbtion on the left channel. I put a 21w bulbe and a 3A fuse, on both +12v inputs in order to prevent irfz44 burning. When I turn on the amp, the left bulb lights up, the right one not. Left channel sounds lower and without dynamic, the right one is fine. All mosfets are ok, all final trnsistors are ok too. After inspection, I found some problems on the PWM chip, a SG3525A: higher DC values if referred to the right one. I checked the chip, reversing the left one on the right side and viceversa, and the problem remains on the left channel, so SG3525A are both ok. I checked also the transistors near to SG3525A but everything seems ok. Have you any idea?
PPI A200 wont power upHide this!Advertise here!
MTX RTP251D wont power up Dr Zeus Car Audio 18 19th June 2011 12:53 PM
Crossfire CFA202 wont power up Dr Zeus Car Audio 8 17th November 2010 11:47 PM
Zapco system 151-A wont power up robertleo Car Audio 5 22nd August 2010 02:23 AM
Ppi a200 mike49504 Car Audio 8 21st March 2010 04:41 AM
Amp wont power on, just keeps blinking, help! Mach1Chris Car Audio 7 4th May 2005 02:49 PM
Copyright ©1999-2017 diyAudio
