Xtant 3300c No Output
Old 7th January 2012, 02:37 AM   #1
SR20DeDweeb is offline SR20DeDweeb  United States
Default Xtant 3300c No Output
I have here 2 xtant 3300c's. Both powers up on my bench via 12volt supply. Red power indicator lights up on both. All external add-on cards removed and jumped for bypass. Noise Gate off. No audio output from either amp. There is DC offset of 3volts accross all speaker outputs for one amp and about 2 volts DC on the other amp. I read somewhere in these forums to check the J108 (driver transistors?) and one amp show ~8.xx volts on pin 1 on all three J108. The other amp shows ~12.xx volts on pin 1 of all three J108. I have access to a scope if you need readings but you will have to guide me as I am a newb when it comes to the scope.
Old 8th January 2012, 12:10 AM   #2
Perry Babin is offline Perry Babin  United States
Pins 1 and 2 should be near 0v. Pin 3 should be at or below -10v.
Old 10th January 2012, 04:01 AM   #3
Sorry for the delay. Babin, you are correct. On J108, pins 1 and 2 are 0v. Pin 3 is at 11.68v on all 3 J108s. I believe the other amp pin 3 has about 10v on all 3 J108s. For now I will just focus on one amp so as not to confuse. I get +44.6v and -42.7v for the rails. The emitter resistors for these are all at 3.26v. I also get +26.38v as well as -24.89v. The emitter resistors for these. 6 are at 3.083v. The other 6 are at 3.094v. Where should I check next.
Old 10th January 2012, 04:09 AM   #4
Negative or positive voltage on leg 3 of the J108 transistors?
Old 10th January 2012, 04:12 AM   #5
Negative voltage
Old 10th January 2012, 04:35 AM   #6
Just wondering if there are any tips for removing the smd resistors. I tested a few that seemed to be off but when I removed them and checked again, they were ok. Did damage a few pads that they were sitting on so had to jump them. Some of them looked darker than the rest but also checked out fine. What am I looking for as far as identifying damaged smd resistors besides the obvious. Thanks.
Old 10th January 2012, 04:48 AM   #7
A strong lighted magnifying glass will often show you which SMD resistors are damaged but in your amp, you have multiple identical channels so you can compare the resistors in one channel to the corresponding resistors in the other channels.
To remove the resistors, apply additional solder to both ends. Heat one end for 2-3 seconds then quickly move the iron to the other end and slide to resistor off of the pads.
Xtant 3300c No OutputHide this!Advertise here!
Xtant 403A output fets brandes.cm Car Audio 3 29th March 2010 03:44 AM
Help with Xtant x603 shawnk Car Audio 50 15th February 2010 05:03 AM
xtant 3300c nath339 Car Audio 4 30th March 2008 02:50 AM
Please help - Xtant 1001DX with power but no output Supatech Car Audio 4 30th August 2005 07:54 AM
Xtant 1001DX Output transistors needed Stooo Car Audio 17 20th October 2004 02:33 AM
