So, I have red through the posts on any amp similar to these, but none seem to answer the symptoms my amps have except the jl. I Am puting it in here to have a question answered about the caps in it. The memphis pops fuses as soon as its powered up and remote is turned on. If power and ground are hooked up, its ok, just when amp is powered up. Last time i did it I had the back off it and put fuses in it and seen smoke. Pulled power and set it to the side. I circled what was smoking.
Memphis ![]() Caps in JL. Took off plastic cap. ![]() The JL comes on no problem, but playes very low. Every 2-3 min it seems to throw power to the subs for an instant. Checked all my settings when testing out the amps. Also have a 300/2 in my car now, so that eliminates my electrical in my car. Also tested outside my car, same problems. |
#2 |
As far as the memphis goes it appears you have shorted output transistors..
The JL AUDIO amp check for any broken legs on the rectifier Most common probllem with JL amps |
#3 |
You should split the two amps into different threads.
Sent from my Punch 60.2
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator |
#4 |
Ill do that if its needed.
#5 |
Start a new thread for the JL.
The Memphis sounds like it simply has shorted output transistors.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#6 |
OK, going to start one for just the JL.
| Memphis 16-PR1KD amp repair help (pix) | raverx3m | Car Audio | 15 | 24th April 2012 08:07 AM |
| Memphis amp 16-MCD1000 | timwebb | Car Audio | 7 | 16th October 2011 04:09 AM |
| problem with my amp memphis 16-pr1kd | pollo1008 | Class D | 0 | 29th December 2009 10:20 PM |
| 500/1 JL Amp drains my batteries | flying143 | Car Audio | 2 | 29th October 2009 08:51 PM |
| FS: JL 500/1 ($500 CAD located in GVA) | Dynamix Lude | Swap Meet | 0 | 27th October 2004 03:21 AM |
| Page generated in 0.07627 seconds (73.96% PHP - 26.04% MySQL) with 10 queries |
