Go Back   Home > Forums > General Interest > Car Audio
Old 2nd January 2012, 09:59 PM   #1
timwebb is online now timwebb  United States
Default groundpounder3000
i got this to repair. just looking at it i noticed the output driver card was worked on. but two ic's were replaced and dont know if there right...this is how i got it. u1 and u2 have been changed
Old 3rd January 2012, 12:28 AM   #2
i cant find a data sheet on the ic. d3 is shorted, i couldnt find a data sheet on it either.
Old 3rd January 2012, 12:57 AM   #3
The ICs are right (IRS21844S or IR21844S will work).
Did you remove D3 to confirm that it was shorted?
Old 3rd January 2012, 01:10 AM   #4
no i just tested d1 with diode check and it tested fine. d3 shorted with diode check. u2 also got hot when powered up.
Old 3rd January 2012, 01:21 AM   #5
If the outputs failed, the driver IC that was driving the failed outputs has almost certainly failed as well.
Old 3rd January 2012, 02:08 AM   #6
i got the amp with no output transistors in it.but from what i see that looks to be the cause.
i can tell by the soldering on the ic's that they have been replaced. some of the solder tabs are missing for the pins that aren't used.
Old 3rd January 2012, 03:51 AM   #7
d3 is good. im looking for the short now.
Old 3rd January 2012, 10:15 AM   #8
Pins 8 and 14 are likely shorted inside the IC.
Edit:
Sorry, that' should read, 7 and 14.
Old 4th January 2012, 12:47 AM   #9
i was looking for a data sheet on the ic but cant find one.
Old 4th January 2012, 12:55 AM   #10
http://www.irf.com/product-info/data...ata/ir2184.pdf
Page generated in 0.08331 seconds (74.51% PHP - 25.49% MySQL) with 10 queries
