Go Back   Home > Forums > General Interest > Car Audio
Old 2nd January 2012, 08:23 PM   #1
seankane's Avatar
Default Rockford Fosgate T-15004
I recieved this amp in for repair.
The left rear channels had DC voltage on the output terminals and the right rear channels had alot of distortion.
I found 6 output fets shorted and 6 source resistors burned to a crisp.
I replaced the 6 output fets and the 6 source resistors. I replaced 6 gate resistors. I found numorous smd resistors out of tolerance and replaced them. I replaced 3 pnp and 3 npn drivers the PZTA56 and PZTA06. I found two 22.1 ohm resistors out of tolerance which were linked to the drivers.
The right rear channels produce audio now but the left rear still has bad distortion. There are about four 5D smd diodes that are linked to the drivers as well. Just wondering if those should be replaced.
I am not familiar with these amps and unsure which are the protection transistors. Wanting to see if I could remove something to get rid of the distortion.
Any clues as to where to look?
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 2nd January 2012, 09:36 PM   #2
Post a photo of the distorted sine wave output with a load connected to the amp.
Old 3rd January 2012, 03:38 AM   #3
seankane's Avatar
The area thats giving me problems is the 4 series area. I posted a pic the first pic is of the problem area.
The second pic is of the waveform on the left rear channel.
I can make a list for you of all the parts I have changed if it would be helpful in troubleshooting for you.
One thing I thought I would mention when the head unit is turned to half volume there is about 3.657 vdc on the channel, turning it any higher causes my meter to bounce between 3.657 and OL
Old 3rd January 2012, 10:17 AM   #4
Was that with a load?
Does the bias control work?
Old 3rd January 2012, 09:59 PM   #5
seankane's Avatar
Yes that was hooked up to a small 4 ohm speaker at low volume.
The bias control does not work.
Old 4th January 2012, 01:47 AM   #6
Removing D4002, 4003, 4004 and 4005 will defeat the protection circuit (like you've done in the smaller amps) to see if it will produce audio. I don't know if it's safe in these amps.
Old 4th January 2012, 06:12 AM   #7
seankane's Avatar
Well since the outputs failed and the source resistors looked like burned hot dogs the protection diodes have probably failed anyway wouldnt you agree?
Whats the worst that could happen?
Old 4th January 2012, 10:21 AM   #8
seankane's Avatar
I replaced D4003, D4004, D4005 and the amp seems to be working. The audio is clean from what I can tell.
The bias control is now working too. I guess the problem was the protection circuit?
I didnt replace D4002 because I am unsure what it is. It has the marking JS but when I look it up it doesnt come back as sot-23 package.
I am not sure if it needs to be replaced or what a good sub would be or even the correct replacement would be.
Any thoughts on D4002?
Old 4th January 2012, 05:12 PM   #9
BAS21LT1 according to the schematic diagram. I wouldn't replace it if it's not defective.
Old 4th January 2012, 07:19 PM   #10
seankane's Avatar
Ok I will leave it alone, wondering if you could e-mail me the schematic. I have another one of these coming in the next few weeks.
Rockford fosgate 4.6 X mike49504 Car Audio 14 28th May 2011 03:35 PM
Rockford Fosgate BD1500.1 mike49504 Car Audio 4 17th March 2011 10:39 PM
Rockford Fosgate T 15004 mike49504 Car Audio 10 17th January 2011 03:23 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
Rockford fosgate Bd1500.1 mike49504 Car Audio 25 21st September 2010 05:24 PM
Page generated in 0.10440 seconds (78.59% PHP - 21.41% MySQL) with 11 queries
